You can see it for yourself, if you download
this:
http://www.caddzone.com/AcMgdHostDefect.zip
Unpack and build the solution, and follow
the instructions to reproduce the bug.
After doing that, move the two DLLS from the
solution to the same folder where AutoCAD is,
and repeat the steps. The problem occurs only
when the two DLLs are not located in the same
folder where acad.exe is.
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Kailas Dhage"
wrote in message news:5636104@discussion.autodesk.com...
Hi Tony,
>>>If you go managed, make sure that you deploy your
managed DLLs in the same folder where acad.exe is,
or they may fail.
Surprising, What kind of failure? Can you through more light on this?
-Kailas Dhage
"Tony Tanzillo" wrote in message
news:5635937@discussion.autodesk.com...
No custom entities, Not all reactors (many are not
exposed), and there are still quite a few things that
aren't exposed to the managed world.
or they may fail.
"Partha" wrote in message
news:5634983@discussion.autodesk.com...
Last time I wrote something in ARX - 3 years back... Now I've to write some
program in ARX (ObjectARX 2007)... What should I use - UnManaged or
Managed - Managed is new to me... Can I use everything (reactors, custom
entities etc) in ManagedARX?
Regards
-Partha
