.NET
Unknown command
4 REPLIES 4
793 Views, 4 Replies
Unknown command
My program compiles with 0 errors and 0 warnings however when I load with netload and run AutoCAD tells me "unknown command" What is the problem?
4 REPLIES 4
Try making the Create function static (Shared in VB).
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4925522@discussion.autodesk.com...
You also may need to make it a SUB. I don't believe you can call a FUNCTION
since function implies a return value. Change it to this and it'll work:
Public Class EmployeeObject
_
Public Shared Sub Create()
-- Mike
___________________________
Mike Tuersley
the trick is to realize that there is no spoon...
Mike,
Function is OK. Here's a piece of code that
works:
face="Courier New">Imports
color=#000000>
System.Runtime.InteropServices
face="Courier New" color=#0000ff size=2>Imports
face="Courier New" color=#000000> Autodesk.AutoCAD.Runtime
Public
size=2>
Class
DemoClass
size=2>Implements
Autodesk.AutoCAD.Runtime.IExtensionApplication
size=2>Public
size=2>Sub
Initialize()
size=2>Implements
Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
size=2>Autodesk.AutoCAD.ApplicationServices.CommandLinePrompts.Message(vbNewLine
+ _
size=2>"DEMO Class successfully loaded..." +
vbNewLine)
size=2>End
size=2>Sub
size=2>
size=2>Public
size=2>Sub
Terminate()
size=2>Implements
Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
size=2>End
size=2>Sub
size=2><Autodesk.AutoCAD.Runtime.CommandMethod("DEMO1")>
_
size=2>Public
size=2>Function
Demo1()
color=#0000ff size=2>End
color=#0000ff size=2>Function
face="Courier New">End
size=2>
size=2>Class
Sepich, you need to
load resulting DLL via AutoCAD's NETLOAD command. Also try to keep a DLL at
location found in AutoCAD's Search/Support Path (or create a new
one).
Maksim Sestic
Public Class
EmployeeObject
<CommandMethod("create")> _
Public Shared Sub
Create()
-- Mike
Mike
Tuersley
no spoon...
Thanks Maksim. I knew that would work but I'm not sure if it does if you
remove your Initialize sub. Easy enough to test, I just haven't had much
time to play lately 😉
-- Mike
Mike Tuersley
”Boost
