.NET
Unhandled Exception C0000005(Access Violation Reading 0x0000) at address 886CEB5
1 REPLY 1
wesbird
808 Views, 1 Reply
When I finish my .net application debug in AutoCAD, I got this error message:
Exception in acmgd.dll ARX Command
Unhandled Exception C0000005(Access Violation Reading 0x0000) at address 886CEB5h
What's reason it could be?
Thank you,
Merry Christmas
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
Khalique
in reply to: wesbird
Most likely it is because you declared a variable and used it without instantiating it.
When C# encounters an exception, it stops at the line where exception occurred. Add a try/catch block and examine the Exception object's message property. It will tell you more about the error.
try
Command that caused error
catch(Exception ex)
Debug.WriteLine(ex.Message);
Add the following using statement if not already added.
using System.Diagnotics;
kr
”Boost
