.NET
Undo Transactions step-by-step within a CommandMethod
3 REPLIES 3
SRSDS
567 Views, 3 Replies
I have a CommandMethod which has a loop that opens and commits transactions until the user is finished with it and exits.
I would like each transaction to be undone seperately but the undo command undoes the CommandMethod (along with all the transactions that occured while in the loop)
Do I need to use the COM StartUndoMark and EndUndoMark to get this working?
Hope someone can help,
3 REPLIES 3
hgasty1001
in reply to: SRSDS
TT implemented a clever way to allow undos in this link: Undo
Gaston Nunez
SRSDS
in reply to: hgasty1001
Dim curdoc As IAcadDocument  is not recognised.
Appologies for my ignorance.but is this a COM component that I need to reference in?
hgasty1001
in reply to: SRSDS
Yes, IAcadDocument can be replaced by Autodesk.AutoCAD.Interop.AcadDocument, you need to set references to  Autodesk.AutoCAD.Interop and Autodesk.AutoCAD.Interop.Common you can find the references in the GAC or the inc folder of the SDK depending on version.
Gaston Nunez
”Boost
