.NET
.NET
SRSDS
Message 1 of 4 (156 Views)
Undo command disables DocumentCollection reactors
156 Views, 3 Replies
04-27-2012 12:29 PM
Can anyone suggest a reason why Undo might disable DocumentCollection reactors?
It has something to do with me undoing the annotation scale as when I remove the line
db.Cannoscale = tstAnnoScale
The problem doesn't occur.
Distinguished Contributor
Artvegas
Message 2 of 4 (136 Views)
Re: Undo command disables DocumentCollection reactors
04-28-2012 12:58 AM in reply to: SRSDS
Sounds strange. Can you post some code that replicates the problem?
Board Manager
StephenPreston
Message 3 of 4 (119 Views)
04-29-2012 07:53 AM in reply to: SRSDS
Hard to say without seeing code. Event handlers can become disabled if you allow an exception thrown in your event handler to propagate to AutoCAD (i.e. if you don't catch and handle the exception in your event handler).
Cheers,
Stephen Preston
Autodesk Developer Network
SRSDS
Message 4 of 4 (114 Views)
04-29-2012 08:28 AM in reply to: StephenPreston
I've only just fixed the problem but I'm not entirely sure where the exact problem was as I changed a few things and moved a few buits of code around.
One thing I found was that two events were bouncing off each other but for some reason it wasn't and endless loop.
