Reading a reply from Tony T. it reminds me how much of the big picture I am missing. Also Tony T. if you put out a design patterns for AutoCAD using .NET I would definitely buy it.
I recently joined ADN hoping there would be good documentation on this, and unless I am missing it there is none.
If you have a question ADN will email back answer, but what good is copying and pasting code if you do not understand it, although I usually understand the code I don't really understand the implementation or the big picture. For example:
If I want a class to be document specific should I let Autocad do the work.( I thought somewhere I read AutoCad will cache that instance with a document and create a new Instance of a class for each new Document. Do not know how or when or even this applies.) so if I make a call to the instance will it reference the instance of the document open. What if I use a Singleton Pattern and use the Open Document to change certain properties and switch documents?
I am not asking for answers to any particular question?
Just a push in the right direction. Of course I have looked at ARXmgd.
Is reading the objectARX docs that .NET wraps a good start?
I have definitely used the ARX documentation to figure things out that I couldn't figure out using the .NET documentation.
As far as "reading" the ARX docs, I guess that depends on how bad you need the sleep
And, in case you haven't found it yet, I also recommend Kean Walmsley's Blog, Through the Interface. Lot's of good stuff there.
http://through-the-interface.typepad.com/through_the_interface/
I am a single dad and in school for Electrical Engineering so I do not sleep
Documentation is very formal descriptions of APIs, what they do,
and so on. While the developer's guide does go into underlying
theory and concepts, it's not that in-depth.
The only thing I can suggest is to download and read the contents
of this and other fora. Unfortunately, with this new forum software
and no NNTP, Autodesk has worked very hard to make that as
difficult as possible, something I find reprehensible and an outright
betrayal of its customers.
Specific question you cited as an example was discussed many
times in posts here.
nttp is still alive and well, just not on the adesk servers and sadly no one here knows or cares as it's been unpopulated since adesk and ms pulled the plugs on their servers.
the nttp side of all these acad groups are still avail through for example eternalSeptember.org or other servers
i wish more people here still used it as it's so much better format for q/a. except the email notification of responses is kinda cool i have to admit.
