.NET
Unable to open block table
2 REPLIES 2
giskumar
640 Views, 2 Replies
Hi all,
I have following code to place circle with given parameters.
When i call this function from a class it is working fine.
When i call this function from button_click event it is terminating at red hilighted line.
Any help to solve this problem.
public void errcle(double rad, string lay, Point3d cnpt)
            Document doc2 = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db2 = doc2.Database;
            Editor ed2 = doc2.Editor;
            Transaction tr2 = db2.TransactionManager.StartTransaction();
            using (tr2)
                BlockTable blktb = tr2.GetObject(db2.BlockTableId, OpenMode.ForWrite) as BlockTable;                BlockTableRecord blktr = tr2.GetObject(blktb[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                Circle cr = new Circle();
                cr.SetDatabaseDefaults();
                cr.Radius = rad;
                cr.Layer = lay;
                cr.Center = cnpt;
                blktr.AppendEntity(cr);
                tr2.AddNewlyCreatedDBObject(cr, true);
                tr2.Commit();
thanks,
Kumar.
2 REPLIES 2
Hallex
in reply to: giskumar
Just an idea, use
 DocumentLock docklock = doc. LockDocument();
using(docklock)
using (tr2)
//rest code here...
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
giskumar
in reply to: Hallex
Hi Hallex,
simply super
Now my form is working well.
Kumar.
”Boost
