.NET
Unable to find an entry point named 'acedInvoke' in DLL 'acad.exe'
3 REPLIES 3
JeffatSJE
1249 Views, 3 Replies
.net 4 change caused the following code to hang (sample from help file)
any documentation on how do fix this?
        [System.Security.SuppressUnmanagedCodeSecurity]
        [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl)]
        extern static private int acedInvoke(IntPtr args, out IntPtr result);
        // Helper for acedInvoke()
        public static ResultBuffer InvokeLisp(ResultBuffer args, ref int stat)
           IntPtr rb = IntPtr.Zero;
           stat = acedInvoke(args.UnmanagedObject, out rb);
           if (stat == (int)PromptStatus.OK && rb != IntPtr.Zero)
               return (ResultBuffer)
              DisposableWrapper.Create(typeof(ResultBuffer), rb, true);
           return null;
J
3 REPLIES 3
_gile
in reply to: JeffatSJE
AFAIK, this is not a related to .NET Framework 4.0 but to the AutoCAD 2013 .NET API.
Replace acad.exe with accore.dll, or, better, use the managed Application.Invoke() method which wraps the ObjectARX acedInvoke method (since A2011).
Gilles Chanteau
GileCAD
GitHub
JeffatSJE
Changing acad.exe to accore.dll worked great!
Thank You! Smiley Happy
Most of my routines use this code to access lisp api call data. If you know of any examples using Application.Invoke() that does the same I would learn something new.
Thanks Again,
Jeff
_gile
As P/Invoking acedInvoke, the Application.Invoke() method requires a single argument as ResultBuffer and returns the LISP return value as a ResultBuffer.
Gilles Chanteau
GileCAD
GitHub
”Boost
