.NET
Active Contributor
DesignProQuig
Message 1 of 2 (127 Views)
UAC stops toolbars loading.
127 Views, 1 Replies
05-30-2012 09:04 AM
H there,
When I try to menuload a .cuix on a machine that has UAC set to high, The menu group comes in, but the toolbars associated with it do not.  I know this sounds like AutoCAD support but it is .net related as the .cuix is loaded through .net.  The pull down appears OK.
If I manually set UAC to it's lowest setting then they come in, is there a reason for this?
Maritn.
http://www.designprosoftware.co.uk/
Active Contributor
DesignProQuig
Message 2 of 2 (108 Views)
Re: UAC stops toolbars loading.
06-02-2012 07:18 AM in reply to: DesignProQuig
Found out why,
The cuix is copied from the Programmes folder to The appdata folder for each new user that logs into the PC.  AutoCAD was unsing the first .cui it came accross witch was in the Programmes folder.  On the vast majority of clients write access is denied here.  So I adjusted the code to only read the one from the appdata folder.
Cheers,
Martin.
Announcements
Need installation help?
