.NET
mzakiralam
Message 1 of 10 (2,221 Views)
Two AutoCAD drawing comparison
2221 Views, 9 Replies
01-17-2013 12:42 AM
Hi All,
I want to do some coding which will compare that 2 autocad drawings are identical or not? Can anybody help me in this regard. Hints with VB code will be appreciated.
Thanks and Regards
zakir
Moderator
Alexander.Rivilis
Message 2 of 10 (2,213 Views)
Re: Two AutoCAD drawing comparison
01-17-2013 02:39 AM in reply to: mzakiralam
If you can explain in great detail what is "identical drawings", then you may be able to get help.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
mzakiralam
Message 3 of 10 (2,205 Views)
01-17-2013 04:42 AM in reply to: Alexander.Rivilis
Suppose, I have one drawing. Now I make a copy of it.  Afterwards I delete few lines from it. I want to compare these 2 drawings whether they are similar or not? The comparison result should tell me that this is not similar. Because I have delete something from the copied drawing. If I do not delete any lines from the copied drawing, then the comparison should tell me  that two drawings are same. This is what I want to mean.
Moderator
Alexander.Rivilis
Message 4 of 10 (2,203 Views)
01-17-2013 04:50 AM in reply to: mzakiralam
mzakiralam wrote:
... If I do not delete any lines from the copied drawing, then the comparison should tell me  that two drawings are same...
If everything were that simple ...
1. What about you add new lines to drawing?
2. What about you change layer of lines?
3. What about you change color of line?
4. What about you combine some lines in block or group?
5. What about you change properties of dwg-file (Title, Subject, Author, Revision...)?
6. etc...etc..etc..
I try to explain how difficult this task in the general case.
mzakiralam
Message 5 of 10 (2,195 Views)
01-17-2013 05:15 AM in reply to: Alexander.Rivilis
You are right. Any change in the duplicated drawing should be reported and should give a message that drawings are not similar.
Distinguished Contributor
djonio
Message 6 of 10 (2,188 Views)
01-17-2013 05:46 AM in reply to: mzakiralam
zakir,
IMHO Mr. Rivilis is trying to tell you this would be a HUGE, almost undoable task. If so I would agree with him.
as some would say ... "Your eyes are bigger than your wallet."
r,
dennis
Moderator
Alexander.Rivilis
Message 7 of 10 (2,180 Views)
01-17-2013 06:09 AM in reply to: djonio
djonio wrote:
zakir,
r,
dennis
This is exactly that I wanted to say. But my English is not allowed so beautifully and laconically describe the situation. :smileytongue:
Zakir. You can begin with this topic: http://www.theswamp.org/index.php?topic=39991.0
mzakiralam
Message 8 of 10 (2,175 Views)
01-17-2013 06:16 AM in reply to: Alexander.Rivilis
Yeah I understand that. This is why my first sentence was "You are right". First I only consider the drawing structure. That is why I was optimistic.
mzakiralam
Message 9 of 10 (2,172 Views)
01-17-2013 06:17 AM in reply to: mzakiralam
Thanks any way for your link :smileyhappy:
Valued Mentor
jeff
Message 10 of 10 (2,166 Views)
01-17-2013 06:26 AM in reply to: mzakiralam
