.NET
Trying to delete table row
2 REPLIES 2
1016 Views, 2 Replies
I'm writing a method to delete table rows in AutoCAD based on the value of the first column. My code is:
public void deleteRow(String openingName)
    Transaction tr = doc.TransactionManager.StartTransaction();
    DocumentLock docLock = doc.LockDocument();
    using (tr)
    using (docLock)
    if (!IsWriteEnabled || !IsReadEnabled) //Committing transactions closes everything for reading and writing so it must be reopened
        tr.GetObject(this.ObjectId, OpenMode.ForRead);
       tr.GetObject(this.ObjectId, OpenMode.ForWrite);
    for (int i = 1; i < NumRows; i++)
        if (Cells[i, 0].GetTextString(FormatOption.ForExpression).Equals(openingName))
            DeleteRows(i, 1);
    GenerateLayout();
    tr.Commit();
However all it does is delete the values of the cells in the row, leaving an empty row. How do I remove the row itself?
2 REPLIES 2
vivek.varma
Merge cells
_gile
The DeleteRows() method should delete the row, not only its contents.
Did you check the Row[i].CanDeleteRows property value?
Gilles Chanteau
GileCAD
GitHub
”Boost
