.NET
Trying to create a custom ribbon, and get an eDuplicateKey error
1 REPLY 1
NLeininger
333 Views, 1 Reply
This happens when I try to test my code, as I have Autocad set to run as an external program.  The following is what shows up in the command window when I run the debugger.
Anyone have and idea on how to stop the error messages?
1 REPLY 1
fenton.webb
in reply to: NLeininger
You will have to fix your code... can we see what the code is doing?
Fenton Webb
AutoCAD Engineering
”Boost
