.NET
true name of dynamic block?
4 REPLIES 4
414 Views, 4 Replies
I want to use the blockname of a given id. With normal blocks it works fine, but dynamic blocks return an anonymous name like *Uxxx. How can i find the true name of the dynamic block?
Dim Btr As BlockTableRecord = CType(ta.GetObject(curBlockRef.BlockTableRecord.ConvertToRedirectedId, OpenMode.ForRead, False), BlockTableRecord)
Dim ProductNo As String = Btr.Name
4 REPLIES 4
EffectiveName property?
wrote in message news:5214891@discussion.autodesk.com...
Thanks, but EffectiveName works in VBA only.
If the IsDynamicBlock property of the BlockReference returns
true, then you use the DynamicBlockTableRecord property to
get the id of the BlockTableRecord, open that and get its name.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
Thanks a lot Tony, it works!
I have a little problem with the property IsDynamicBlock, because it sometimes was false though it was a dynamic block, so i use the anonymous blockname.
For other users i complete my code:
If Left(Btr.Name, 1) = "*U" Then
Dim dynObjectID As ObjectId = curBlockRef.DynamicBlockTableRecord
ProductNo = Left(Btr.Name, Len(Btr.Name) - 1)
Dim dynBtr As BlockTableRecord = CType(ta.GetObject(dynObjectID, OpenMode.ForRead, False), BlockTableRecord)
ProductNo = dynBtr.Name
Else
ProductNo = Btr.Name
”Boost
