I'm writing a program to import a WMF into the AutoCad Drawing. I haven't been able to find any reference for the import command, so I can't figure out why it's not working. According to Visual Studio, the Import command needs these things to work.
acadDoc.Import(FileName As String, InsertionPoint As Object, ScaleFactor As Double) As Object
Simplified Code:
Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Interop Dim AcadApp As Autodesk.AutoCAD.Interop.AcadApplication AcadApp = CType(GetObject(, "AutoCAD.Application.18.2"), Autodesk.AutoCAD.Interop.AcadApplication) acadDoc = AcadApp.ActiveDocument acadDoc.Import("C:\Users\C\Documents\Drawing1.wmf", New Point3d(2, 2, 0), 2.0)
When I comment out the last line of code,
It runs fine.
The error I'm getting is when I run it AutoCAD,
************** Exception Text ************** System.ArgumentException: Value does not fall within the expected range. at System.StubHelpers.ObjectMarshaler.ConvertToNative(Object objSrc, IntPtr pDstVariant) at Autodesk.AutoCAD.Interop.IAcadDocument.Import(String FileName, Object InsertionPoint, Double ScaleFactor) at TestSelectingFiltering.TestSelecting.MyCommands.FilterBlueCircleOnLayer0() at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
Any help would be greatly appreciated,
Thanks!
Solved by norman.yuan. Go to Solution.
Well, the error message says exactly why the exception happems: ArgumentException, which means one of the parameter you passed to the AcadDocument.Import() method is wrong.
The second argument of the Import method expects a ARRAY of double (3 elements), representing an point. What you passed in is an Point3d staructure. Acad COM object does not know what Point3d is.
So, you need to change your code like:
Dim point(0 To 2) as double
point(0)=2.0 : point(1)=2.0 : point(2)=0.0
acadDoc.Import("C:\Users\C\Documents\Drawing1.wmf", point, 2.0)
Norman Yuan
