TrayItem Icon disappears
Hi all
Can someone help me with custom trayitem/pane icon. I have the following code which is supposed to load a custom icon. The problem i am having is that the icon seems to disappear in Autocad.
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Public Class Class1
Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
Overridable Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
AddTrayItems()
End Sub
Function GetEmbeddedIcon(ByVal strName As String) As Drawing.Icon
Return New Drawing.Icon(System.Reflection.Assembly.GetExecutingAssembly.GetManifestResourceStream(strName))
End Function
Sub AddTrayItems()
Try
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim ti As New TrayItem()
ti.ToolTipText = "MyCadAddon Info"
ti.Icon = GetEmbeddedIcon("MyCadAddon.blue.ico")
Application.StatusBar.TrayItems.Add(ti)
Dim bw As New TrayItemBubbleWindow()
bw.Title = "MyCadAddon Application:"
'bw.HyperText = ""
' bw.HyperLink = ""
bw.Text = "This application has been loaded sucessfully"
bw.IconType = IconType.Information
ti.ShowBubbleWindow(bw)
Catch
End Try
End Sub
Overridable Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
End Sub
End Class
see also attached icon
Thosti
i'm in the same situation. I tried to load a custom icon as TrayItem, however sometimes I can see it but mostly there is only the space without the icon. Icons grabbed from an existing acad trayitem were always shown.
Have you found any solution?
Thanks Thosti
michael_vanhoose
Try reloading it on Document events.  It work most of the time for me.  Once and awhile I notice it gone.  But, not as much since I added on the Document Created event and Active Event.
Balaji_Ram
I could recreate the same problem when an icon created using Visual studio is used.
Try creating an icon which similar to acad.ico (256 x 256, 32 bit).
Balaji
Developer Technical Services
Autodesk Developer Network
Thosti
Thanks for reply,
I tried both suggestions (acad.ico with 256x256, which is included as embedded resource in the project and adding events to the doument) but with no success. So I simplyfied my code to generate this TrayItem by executing a command.
Here is the codesnipe
static Autodesk.AutoCAD.Windows.TrayItem oneNewTi = null;
//Funktion um befehle zu testen[CommandMethod("test")] public static void test() { try { if (oneNewTi == null) { System.Drawing.Icon ic; //Laden des Icons aus der Resourcendatei System.Reflection.Assembly thisExe = System.Reflection.Assembly.GetExecutingAssembly(); System.IO.Stream file = thisExe.GetManifestResourceStream("CAD.Bilder.acadmap.ico");
//ic = new System.Drawing.Icon(file, 256, 256); ic = new System.Drawing.Icon(file); oneNewTi = new Autodesk.AutoCAD.Windows.TrayItem(); oneNewTi.Visible = true; oneNewTi.Icon = ic; oneNewTi.ToolTipText = "Verbindung"; //Hinzufügen zur Statusbar und Anzeige aktualisieren Application.StatusBar.TrayItems.Add(oneNewTi); }
Application.StatusBar.Update(); } catch (System.Exception ex) { Application.ShowAlertDialog("Fehler in Funktion Test.\nMeldung: " + ex.Message); } finally { //MainApp.acadFunctions.UpdateApplication(); } //System.Diagnostics.Process.Start }
It ended with the same behaviour. Executing test-command adds the icon to the statusbar. The icon is visible. When moving mouse-cursor through acadmenu (we do not use multifunction-bar) for example, so that the statusbar is not visible for a short time - icon is gone when statusbar is visible again.
Executing test-command again doesn't make icon visible. There is only the empty space.
Could anybody reproduce this behaviour?
Regards, thosti
Thosti
here is the solution that worked for me.
When the icon is defined as static global variable then the icon does not disappear.
I will have a look at my "little icon" in further time.
Thanks for all replies
Thosti
tiancao1001
The same code, why come out two icons?
