.NET
trapping drag and drop
6 REPLIES 6
chuck.han
696 Views, 6 Replies
Is there a way to trap drag-and-drop INTO an AutoCAD window using the C# API? For example, I want to customize AutoCAD's behavior when I'm dropping in i-drop content from IE.
thanks in advance, Chuck
(Hi Albert!)
6 REPLIES 6
chuck.han
in reply to: chuck.han
Since, Autodesk hasn't wrapped the following globals:
acedRegisterCustomDropTarget(IDropTarget*);
acedRevokeCustomDropTarget();
It looks like a no go. Any suggested hacks would be appreciated...
Chuck
These functions should not be used anymore. You should use
acedStartOverrideDropTarget, acedEndOverrideDropTarget instead.
We do wrap these 2 on the .NET API but the manner we do will make it
difficult to use them the way you want them. Look at the
Autodesk.AutoCAD.ApplicationServices.Application.DoDragDrop function. We
only allow you to override the drop target for the duration of DoDragDrop.
Albert
wrote in message news:4863116@discussion.autodesk.com...
Chuck
chuck.han
How do I initiate a DoDragDrop when the origin of the drag-and-drop is coming from an external app (for example, dragging i-drop content from IE)? Do I need to do something funky with PointFilter/PointMonitor?
thanks, Chuck
I don't think it is possible. You will have to fall back to C++ or
(P/Invoke). We probably want to provide an event where you can hook the drop
target even when you didn't initiate the drag. I have this logged as a wish
list item.
albert
wrote in message news:4863716@discussion.autodesk.com...
thanks, Chuck
chuck.han
I've already pretended to be a C++ programmer again. Thanks. However, perhaps this isn't the forum for this question, but since it is related, I'll go ahead and describe another thing that has come up:
After I load the sample, arxdragdrop, drag-and-drop from external apps into ACAD seems to be broken. When I drag i-drop content in after loading the arx app, I get a menu with the items 'List Files' and 'Cancel' instead of the drag-and-drop sequence (it works fine BEFORE loading the arx app). It seems to be going through the droptarget.cpp code WITHOUT a call to acedStartOverrideDropTarget() that only gets called when initiating a drag-and-drop from the arx-created window.
chuck.han
Never mind. I assumed that it was aced{Start,End}OverrideDropTarget()/aced that was dealing with external drag-and-drops, but it is aced{Add,Remove}DropTarget().
”Boost
