.NET
transparent command
0 REPLIES 0
Message 1 of 1
214 Views, 0 Replies
transparent command
I have write a command that show a form .On this form i have a button that
ask to select a position.
when i select a position i want use transparent command like 'zoom ,etc.
if i write in this way work correct but when i minimize the form autocad is
locked.
Sub Mycommand
Dim FrmMain As New FrmMain
Application.ShowModalDialog(AcAs.Application.MainWindow, FrmMain, False)
end sub
in this way i can minimize the form and run other command like "LINE",etc,
but when i try to give 'zoom or other transparent command the system say
"required a point or a keyword".
Sub Mycommand
Application.ShowModelessDialog(AcAs.Application.MainWindow, FrmMain, False)
end sub
Some help?
Thank's in advance
GPaolo
0 REPLIES 0
”Boost
