.NET
nijhuis
Message 1 of 5 (304 Views)
transparancy viewportoverride
304 Views, 4 Replies
02-10-2012 04:54 AM
Does anyone how to make a layer or an entity transparant within a viewport?
I figured out the following code found in:
http://through-the-interface.typepad.com/through_the_interface/2010/06/creating-transparent-hatches-...
It gives an error at New Autodesk.AutoCAD.Colors.Transparency(127)
Using transactie AsTransaction = DWG.TransactionManager.StartTransaction
Dim Layertable AsLayerTable = DWG.LayerTableId.GetObject(OpenMode.ForRead)
Dim VP AsViewport = transactie.GetObject(Doc.Editor.CurrentViewportObjectId, OpenMode.ForWrite)
Dim LVPO AsLayerViewportProperties
ForEach LayerID In Layertable
Dim LaagTabelRec AsLayerTableRecord = transactie.GetObject(LayerID, OpenMode.ForRead)
LVPO = LaagTabelRec.GetViewportOverrides(VP.Id)
LVPO.Transparency = New Autodesk.AutoCAD.Colors.Transparency(127)
Next
transactie.Commit()
EndUsing
I use autocad 2011 64bit with visual studio 2008.
i tried Cbyte(127) and that did the trick!
thanks!
Alfred.NESWADBA
Message 2 of 5 (286 Views)
Re: transparancy viewportoverride
02-12-2012 12:20 PM in reply to: nijhuis
I used the following code and for me it does not interrupt at the line for setting the layer-override-transparency ..... as long as I have a layout active and I'm IN a viewport :smileywink:
Of course it crashes if I have the tab "Model Space" active (so I don't have a layout active)
   <Runtime.CommandMethod("ADESK_VPLayerTransparency")> _
   Public Shared Sub ADESK_VPLayerTransparency()
      Dim tDwg As ApplicationServices.Document = ApplicationServices.Application.DocumentManager.MdiActiveDocument
      Dim tDwgLock As ApplicationServices.DocumentLock = Nothing
      Try
         tDwgLock = tDwg.LockDocument
         Using transactie As DatabaseServices.Transaction = tDwg.TransactionManager.StartTransaction
            Dim Layertable As DatabaseServices.LayerTable = CType(transactie.GetObject(tDwg.Database.LayerTableId, DatabaseServices.OpenMode.ForRead), DatabaseServices.LayerTable)
            Dim LVPO As DatabaseServices.LayerViewportProperties
            For Each LayerID As DatabaseServices.ObjectId In Layertable
               Dim LaagTabelRec As DatabaseServices.LayerTableRecord = CType(transactie.GetObject(LayerID, DatabaseServices.OpenMode.ForWrite), DatabaseServices.LayerTableRecord)
               LVPO = LaagTabelRec.GetViewportOverrides(tDwg.Editor.CurrentViewportObjectId)
            Next
            transactie.Commit()
         End Using
      Catch ex As Exception
         Call MsgBox("Unknown error in 'ADESK_VPLayerTransparency'" & vbNewLine & ex.Message)
      Finally
         If tDwgLock IsNot Nothing Then tDwgLock.Dispose() : tDwgLock = Nothing
      End Try
   End Sub
HTH, - alfred -
Alfred NESWADBA
nijhuis
Message 3 of 5 (280 Views)
02-13-2012 12:08 AM in reply to: nijhuis
Thanks for your reply.
When i use new ...colors.transparency(127)  visual studio gives me an error. (see attachement 1)
i tried to replace 127 with an byte-value and visual studio gives me another error. (see attachement 2)
Alfred.NESWADBA
Message 4 of 5 (274 Views)
02-13-2012 12:33 AM in reply to: nijhuis
what version of AutoCAD do you use? I tried it with 2012(64bit) and Option Strict ON, and I don't get a message, neither during code-writing nor during runtime.
Could you try:
LVPO.Transparency = New Autodesk.AutoCAD.Colors.Transparency(CByte(127))
- alfred -
Alfred NESWADBA
nijhuis
Message 5 of 5 (273 Views)
02-13-2012 12:38 AM in reply to: nijhuis
thanks!
