.NET
T72
New Member
T72
Message 1 of 2 (180 Views)
TransientManager fatal error
180 Views, 1 Replies
12-10-2012 12:44 AM
Good afternoon.
Sometimes when you call
TransientManager.CurrentTransientManager.EraseTransients (TransientDrawingMode.DirectShortTerm, 128, new IntegerCollection ()); fatal error occurs (may 1000 run normally, and then put AutoCAD). There is so deep that the try / catch does not help. The call is from OnGripStatusChanged (Entity entity, GripStatus status)
add this:
Autodesk.AutoCAD.GraphicsInterface.TransientManager.CurrentTransientManager.AddTransient (entity, Autodesk.AutoCAD.GraphicsInterface.TransientDrawingMode.DirectShortTerm,
I update:
TransientManager.CurrentTransientManager.UpdateTransient (entity, new IntegerCollection ());
Is it possible to somehow prevent the bug or correct drown?
Thank you.
ADN Support Specialist
Balaji_Ram
Message 2 of 2 (136 Views)
Re: TransientManager fatal error
12-14-2012 09:13 AM in reply to: T72
Sorry, but there is not much suggestion that can be provided for such rarely reproducible problems.
You may need to isolate the part of the code that uses the transient graphics and try to reproduce the crash.
I can understand that this is quite difficult but I dont see any other way to know what could be causing it.
Balaji
Developer Technical Services
Autodesk Developer Network
