.NET
transforming DWG Entities to Blocks
4 REPLIES 4
Nawara17
342 Views, 4 Replies
Hi everyone,
Please, can somebody help? i am a programmer, and i am novice in autocad drawings. I had attached a drawing, that i don't know how it was created. it seems that the entities were grouped. but they are not blocks. am I right????
i want to read each group of entities and add a block definition for it if i didn't read similar group before and the group of entities that i read should be a block reference. can i do that using C#?? and are these groups of entities or blocks??
or everything that i said is wrong??
Thanks in advance 🙂
4 REPLIES 4
Nawara17
in reply to: Nawara17
Sorry this is the attachment.
mjwalsh51
Nawara17,
The entities are not grouped or made into blocks. Go to help & you will see that creating blocks are pretty straightforward.
You can tell what an entity is selected by clicking on it & it is hilighted. if the properties window is open you will see what type of entity or entities are there. If you are really good with C# it would be nice if you would share some of your successes.
The advantage to blocks usually is attaching associated data & subnesting other blocks etc. Also the ability to reuse the already defined group of entities called a block.
I do not know of a situation where it makes sense to initially create block with any type of programming.
I personally think that connecting just the entity's xdata directly to a relational database makes more sense than blocks but requires some programming ability.
Nawara17
thanks Mike, I found that there are entities when I created this peace of code.
using System.Runtime.InteropServices;
using System.Windows.Forms;
using System.Collections;
using AcadAPP=Autodesk.AutoCAD.ApplicationServices.Application;
namespace ClassLibrary4
/// Summary description for Class1.
public class Class1:Autodesk.AutoCAD.Runtime.IExtensionApplication
public void Initialize()
Autodesk.AutoCAD.Interop.AcadApplication AcadApp=(Autodesk.AutoCAD.Interop.AcadApplication)Marshal.GetActiveObject("AutoCAD.Application.16.2");
Autodesk.AutoCAD.Interop.AcadDocument AcadDoc=AcadApp.ActiveDocument;
Database db = HostApplicationServices.WorkingDatabase;
Transaction trans = db.TransactionManager.StartTransaction();
try
BlockTable bt = (BlockTable)trans.GetObject(HostApplicationServices.WorkingDatabase.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
//MessageBox.Show();
foreach (ObjectId id in btr)
MessageBox.Show("HI");
Entity ent = (Entity)trans.GetObject(id, OpenMode.ForWrite, false);
////////////////////////////////The following code i copied it from RonaldF Message in
////////////// http://discussion.autodesk.com/thread.jspa?messageID=5205357
ObjectId[] ids = new ObjectId[1];
ids[0] = ent.Id;
SubentityId index = new SubentityId(SubentityType.Edge, 0);
FullSubentityPath path = new FullSubentityPath(ids, index);
ent.Highlight(path, true);
finally
trans.Dispose();
public void Terminate()
I found that when each message box appear the whole shelves where highlighted.
if I create the code which i asked to I will post it here in this discussion. Nawara17
Nawara17
ent.equals(anotherEnt);
ent.CompareTo(anotherEnt);
these two statments are comparing the objects not the shapes of the entities.
Please, Can anybody tell me, how could i know by comparing two entities that their shapes are similar??
Thanks in advance.
Nawara==>Noora
”Boost
