Hallo,
I'm trying to move my project from VS2010 to VS2012. I can open project and I belive I can build a solution, but while trying to debug I get the information that It can not find destination element "C:\Program Files\Autodesk\AutoCAD 2013\acad.exe" and advice to set property OutputPath and AssemblyName.
Where can I find this properties? Is there any better way to transfer my project.
Thanks for your Advice!
W. Janik
Solved by mconley. Go to Solution.
Right click the project in "Solution Explorer" and select "Properties". Then select "Debug" tab on the left. In the "Start external program" text box, enter/select AutoCAD 2014's acad.exe.
Norman Yuan
