.NET
SRSDS
Message 1 of 4 (169 Views)
Transaction not needed?
169 Views, 3 Replies
05-20-2013 10:59 AM
Just curious about this. Why would the following code not require a transaction?
Essentially filtering and erasing objects.
            Dim psr As PromptSelectionResult = ed.SelectAll(filter)
            If psr.Status = PromptStatus.OK Then
                Dim idarray As ObjectId() = psr.Value.GetObjectIds()
                For Each ObjID In idarray
                    Dim Ent As Entity = ObjID.GetObject(OpenMode.ForWrite)
                    If TypeOf Ent Is Polyline Then
                        Ent.Erase()
                    End If
                Next
            End If
Valued Mentor
DiningPhilosopher
Message 2 of 4 (151 Views)
Re: Transaction not needed?
05-20-2013 02:19 PM in reply to: SRSDS
                        Ent.Erase()
                    End If
                Next
            End If
The code does require a transaction. If it doesn't fail, it is because there is an active transaction in the document you're running it in.
The ObjectId.GetObject() method simply calls the GetObject() method of the active Transaction returned by the TransactionManager's TopTransaction property, and if there is no active transaction, it will fail.
Hallex
Message 3 of 4 (147 Views)
05-20-2013 02:21 PM in reply to: SRSDS
Take a look at this page for more
http://spiderinnet1.typepad.com/blog/2012/04/open-direct-or-use-transaction-to-getobject-in-autocad-...
SRSDS
Message 4 of 4 (112 Views)
05-22-2013 04:11 AM in reply to: Hallex
Thankyou both. I did have an open transaction in a parent routine. I didn't realise that it was being used.
