.NET
Transaction.GetObject() throwing error
3 REPLIES 3
d_gray
447 Views, 3 Replies
I am getting the following error when using Transaction.GetObject() command "Operation is not valid due to the current state of the object."
I have an ObjectIdCollection that i loop round and try
Dim ent As aaDS.Entity = CType(t.GetObject(oid, OpenMode.ForRead), aaDS.Entity)
I've used the same line of code a good few times but this morning it's not playing ball and throwing the above error.
Is there any way i can check the current state of the object to find out what is wrong so that i know where to look? Or any pointers in general?
3 REPLIES 3
in reply to: d_gray
Hi.
I'm not sure if this will help but it's worth a try.
Try to lock the document and when you are done dispose the lock.
Autodesk.AutoCAD.ApplicationServices.DocumentLock documentLock =
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument();
Regards
Peter
wrote in message news:5617442@discussion.autodesk.com...
aaDS.Entity)
d_gray
in reply to: d_gray
Thanks Peter, I finally figured out that i hadn't disposed of a transaction!
rakeshkava
in reply to: d_gray
can i get to know what u exactly did u solve the issue a sample piece of code would be more useful
thanks in advance
”Boost
