.NET
Toolbar problem
0 REPLIES 0
Message 1 of 1
rubendm
143 Views, 0 Replies
Toolbar problem
Hi all,
I need to create a toolbar for an app. I want the toolbar to load on startup, so I created it at my IExtensionApplication implementation class. I can see the toolbar when AutoCAD starts up, but once the IExtensionApplication.Initialize() method is executed, the toolbar hides again. So I am wandering if this is the right place to create the toolbar.
Thanks in advance 🙂
P.S.: I attached the source of my IExtensionApplication implementation class.
Rubén D.M.
Message was edited by: rubendm
Hi again,
I forgot to give more important details...
I am using AutoCAD 2006, ObjectARX 2006 and VS 2005.
When I use the NETLOAD command to load my app DLLs, it works fine. But if I use demand loading, the problem appears (the toolbar appears and a second later it disappears)
0 REPLIES 0
”Boost
