I have created Tool Palette with blocks.
Using a C# library I want access the Tool Palette and create an entity (BlockReference) using it - how to do this?
suppose you have added a button to the userControl,you can add you operation code under the Button_Click Event
besides, before you operation,you should lock the document,or you may get einvalidLock error
