.NET
Toggle LWDISPLAY system variable
9 REPLIES 9
Message 1 of 10
SRSDS
1595 Views, 9 Replies
Can someone suggest why I would get an eInvalidInput error when toggling  a system variable.
I've tried a few things which is why it's 4 lines instead of 1.
        Dim lwdisplay As Object = Application.GetSystemVariable("LWDISPLAY")
        If CShort(lwdisplay) = 0 Then
            Application.SetSystemVariable("LWDISPLAY", CShort(1))
  It generally works but every so often produces an error and I can't figure out why.
9 REPLIES 9
Message 2 of 10
Alfred.NESWADBA
in reply to: SRSDS
at least the question is the line ... in which line does your code throw an exception?
And for doing that in one line ... use this (but it's not faster and it's not easier to read):
   <Runtime.CommandMethod("ADESK_ToggleLWDisp")> _
   Public Shared Sub ADESK_ToggleLWShow()
      Application.SetSystemVariable("LWDISPLAY", Math.Abs(CType(Application.GetSystemVariable("LWDISPLAY"), Integer) - 1))
   End Sub
 this command I have tried (many times) with 2010/32bit, 2010/64bit, 2012/64bit and I could not reproduce a crash. The difference might be that I run that from a command?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
SRSDS
in reply to: Alfred.NESWADBA
Hi Alfred,
I must have forgotten to look into this but have rediscoverd the problem.
Even using
 I still get an eInvalidInput error.
Seems like a basic toggle. 2011/32bit here.
Message 4 of 10
Alfred.NESWADBA
in reply to: SRSDS
.... your code is not the same I wrote, your code just turns ON LWDISPLAY but never OFF.
What line does crash? What message do you get as Exception.Message? Have you tried my command exactly in the way I prepared it?
- alfred -
Alfred NESWADBA
Message 5 of 10
SRSDS
It should do the same I would have thought. If 0 the abs(-1) should turn it on.
            Try
                Application.SetSystemVariable("LWDISPLAY", CInt(1))
            Catch
                Try
                Catch
                    Try
                        Application.SetSystemVariable("LWDISPLAY", CBool(1))
                    Catch
                        MsgBox("?")
                    End Try
                End Try
            End Try
 I get either eInvalidInput or "Value does not fall within the expected range".
Message 6 of 10
Alfred.NESWADBA
in reply to: SRSDS
My code did toogle LWDISPLAY, if it's 0 then I turn it to 1, if it's one I change it to 0.
Your previous code had an if LWDISPLAY = 0 then included, so if LWDISPLAY was 1 there was never changed back to 0.
However, that's not the problem at the moment. Your code never works? Let me know what AutoCAD you exactly have now:
  • AutoCAD .... or vertical Product (like Mech, Map3D, Civil3D, ...)
  • what release?
  • 32bit/64bit?
  • what servicepack is installed
  • what version of VisualStudio do you have?
  • what Framework does your App use?
...maybe we get any info that gives us a chance to work on/to check.
- alfred -
Alfred NESWADBA
Message 7 of 10
Hallex
in reply to: SRSDS
How about avoid using VBA-like types
        Public Sub togglelwdisplay()
            Dim lwdisplay As Short = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("LWDISPLAY")
            If lwdisplay = 0 Then
                Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("LWDISPLAY", 1)
            Else
                Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("LWDISPLAY", 0)
        End Sub
 VBA-like types:
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 8 of 10
SRSDS
in reply to: Hallex
I think it's got something to do with using code in a palette.
It works fine when I move it to  the initialize component.
Attached is a VERY simple example of what I'm experiencing if someone's got time to look.
Message 9 of 10
gopinath.taget
in reply to: SRSDS
If it works in the Iniitialize component and not in a palette, it usually means your having a problem with the contexts (application/document contexts). Can you please try locking the active document in the palette code before you try to change the variable?
<code>
using(DocumentLock lk = Application.DocumentManager.MdiActiveDocument.LockDocument())
    // Do your thing
</code>
Message 10 of 10
SRSDS
in reply to: SRSDS
That was the solution.
My thanks to you and also Alfred and & Hallex.
Sorry for the trouble.
”Boost
