.NET
Thumbnail.OCX for .NET 64 bit
5 REPLIES 5
SRayC
1023 Views, 5 Replies
Back in the day I used the Thumbnail.ocx to display a preview of a dwg file in a form.
I need to upgrade (re-write) an old VB6 program to the 21st centry using VB.NET and was wondering if there is a new version or a subsitute that I could use, maybe something from TrueView?
Any help is greatly appreciated.
Ray C.
5 REPLIES 5
norman.yuan
in reply to: SRayC
You can find .NET code that retrieves thumbnail bitmap image from *.dwg file here:
http://www.theswamp.org/index.php?topic=30985.msg470910#msg470910
http://www.theswamp.org/index.php?topic=45598.msg507524#msg507524
Norman Yuan
Drive CAD With Code
SRayC
in reply to: norman.yuan
Looks great.
This is a bit over my head but when I create my class it is throwing an error on the line
fs.CopyTo(ms, imageHeaderStart)
SRayC
in reply to: SRayC
Sorry about that hit the worng key and submitted the post to quick.
As I was syaing it is posting an development error that
'CopyTo' is not a member of 'System.IO.FileStream'
Have you had a chance to use that code?
Thanks for the help
Ray C.
norman.yuan
in reply to: SRayC
FileStream.CopyTo() method is only available since .NET4.0. Since all my Acad development targets Acad2012 or later, I stoped using .NET2/3.x.
Yes, I used the code with minor change, worked OK with AutoCAD 2012's drawing. Here is the static class I use:
using System;
using System.Drawing;
using System.IO;
namespace DrawingThumbnail
    /// <summary>
    /// This code is originally from http://www.theswamp.org:
    /// http://www.theswamp.org/index.php?topic=30985.msg470910#msg470910
    /// http://www.theswamp.org/index.php?topic=45598.msg507524#msg507524
    /// Minor code change has be made
    /// </summary>
    public static class DwgThumbnail
        public static Image GetBitmapFromDwgFile(string dwgFile)
            if (!File.Exists(dwgFile))
                throw new FileNotFoundException("Cannot find file: \"" + dwgFile + "\"");
            if (!Path.GetExtension(dwgFile).ToUpper().EndsWith("DWG"))
                throw new ArgumentException("Wrong file type: not a *.DWG file.");
            Image img = null;
            using (FileStream fs = new FileStream(dwgFile, FileMode.Open, FileAccess.Read, FileShare.ReadWrite))
                using (BinaryReader br = new BinaryReader(fs))
                    fs.Seek(0xd, SeekOrigin.Begin);
                    fs.Seek(0x14 + br.ReadInt32(), SeekOrigin.Begin);
                    byte bytCnt = br.ReadByte();
                    if (bytCnt <= 1)
                        return null;
                    int imageHeaderStart = 0;
                    int imageHeaderSize = 0;
                    byte imageCode = 0;
                    for (short i = 1; i <= bytCnt; i++)
                        imageCode = br.ReadByte();
                        imageHeaderStart = br.ReadInt32();
                        imageHeaderSize = br.ReadInt32();
                        if (imageCode == 2)
                            // BMP Preview (2012 file format)
                            // BITMAPINFOHEADER (40 bytes)
                            br.ReadBytes(0xe);
                            //biSize, biWidth, biHeight, biPlanes
                            ushort biBitCount = br.ReadUInt16();
                            br.ReadBytes(4);
                            //biCompression
                            uint biSizeImage = br.ReadUInt32();
                            //br.ReadBytes(0x10); //biXPelsPerMeter, biYPelsPerMeter, biClrUsed, biClrImportant
                            fs.Seek(imageHeaderStart, SeekOrigin.Begin);
                            byte[] bitmapBuffer = br.ReadBytes(imageHeaderSize);
                            uint colorTableSize =
                                Convert.ToUInt32(Math.Truncate((biBitCount < 9) ? 4 * Math.Pow(2, biBitCount) : 0));
                            using (MemoryStream ms = new MemoryStream())
                                using (BinaryWriter bw = new BinaryWriter(ms))
                                    bw.Write(Convert.ToUInt16(0x4d42));
                                    bw.Write(54u + colorTableSize + biSizeImage);
                                    bw.Write(new ushort());
                                    bw.Write(54u + colorTableSize);
                                    bw.Write(bitmapBuffer);
                                    img = new Bitmap(ms);
                        else if (imageCode == 6)
                            // PNG Preview (2013 file format)
                                fs.CopyTo(ms, imageHeaderStart);
                                img = Image.FromStream(ms);
                        else if (imageCode == 3)
                            //return null;
            return img;
 HTH
Norman Yuan
Drive CAD With Code
SRayC
That's what I concluded. I'm using VS2008, does not support .NET 4.0.
Time for an upgrade.
Thanks for all your help.
”Boost
