Back in the day I used the Thumbnail.ocx to display a preview of a dwg file in a form.
I need to upgrade (re-write) an old VB6 program to the 21st centry using VB.NET and was wondering if there is a new version or a subsitute that I could use, maybe something from TrueView?
Any help is greatly appreciated.
Ray C.
Solved by norman.yuan. Go to Solution.
You can find .NET code that retrieves thumbnail bitmap image from *.dwg file here:
http://www.theswamp.org/index.php?topic=30985.msg470910#msg470910
http://www.theswamp.org/index.php?topic=45598.msg507524#msg507524
Norman Yuan
FileStream.CopyTo() method is only available since .NET4.0. Since all my Acad development targets Acad2012 or later, I stoped using .NET2/3.x.
Yes, I used the code with minor change, worked OK with AutoCAD 2012's drawing. Here is the static class I use:
using System; using System.Drawing; using System.IO; namespace DrawingThumbnail { /// <summary> /// This code is originally from http://www.theswamp.org: /// http://www.theswamp.org/index.php?topic=30985.msg470910#msg470910 /// http://www.theswamp.org/index.php?topic=45598.msg507524#msg507524 /// Minor code change has be made /// </summary> public static class DwgThumbnail { public static Image GetBitmapFromDwgFile(string dwgFile) { if (!File.Exists(dwgFile)) { throw new FileNotFoundException("Cannot find file: \"" + dwgFile + "\""); } if (!Path.GetExtension(dwgFile).ToUpper().EndsWith("DWG")) { throw new ArgumentException("Wrong file type: not a *.DWG file."); } Image img = null; using (FileStream fs = new FileStream(dwgFile, FileMode.Open, FileAccess.Read, FileShare.ReadWrite)) { using (BinaryReader br = new BinaryReader(fs)) { fs.Seek(0xd, SeekOrigin.Begin); fs.Seek(0x14 + br.ReadInt32(), SeekOrigin.Begin); byte bytCnt = br.ReadByte(); if (bytCnt <= 1) { return null; } int imageHeaderStart = 0; int imageHeaderSize = 0; byte imageCode = 0; for (short i = 1; i <= bytCnt; i++) { imageCode = br.ReadByte(); imageHeaderStart = br.ReadInt32(); imageHeaderSize = br.ReadInt32(); if (imageCode == 2) { //----------------------------------------- // BMP Preview (2012 file format) //----------------------------------------- // BITMAPINFOHEADER (40 bytes) br.ReadBytes(0xe); //biSize, biWidth, biHeight, biPlanes ushort biBitCount = br.ReadUInt16(); br.ReadBytes(4); //biCompression uint biSizeImage = br.ReadUInt32(); //br.ReadBytes(0x10); //biXPelsPerMeter, biYPelsPerMeter, biClrUsed, biClrImportant fs.Seek(imageHeaderStart, SeekOrigin.Begin); byte[] bitmapBuffer = br.ReadBytes(imageHeaderSize); uint colorTableSize = Convert.ToUInt32(Math.Truncate((biBitCount < 9) ? 4 * Math.Pow(2, biBitCount) : 0)); using (MemoryStream ms = new MemoryStream()) { using (BinaryWriter bw = new BinaryWriter(ms)) { bw.Write(Convert.ToUInt16(0x4d42)); bw.Write(54u + colorTableSize + biSizeImage); bw.Write(new ushort()); bw.Write(new ushort()); bw.Write(54u + colorTableSize); bw.Write(bitmapBuffer); img = new Bitmap(ms); } } } else if (imageCode == 6) { //------------------------------------------- // PNG Preview (2013 file format) //------------------------------------------- fs.Seek(imageHeaderStart, SeekOrigin.Begin); using (MemoryStream ms = new MemoryStream()) { fs.CopyTo(ms, imageHeaderStart); img = Image.FromStream(ms); } } else if (imageCode == 3) { //return null; } } } } return img; } } }
HTH
Norman Yuan
