.NET
Active Contributor
0 Kudos
Post 1 of 13
ThisDrawing.Path equivalent
1114 Views, 12 Replies
01-05-2010 05:29 AM
What's the equivalent of ThisDrawing.Path in VB.NET?
Here's what I think it should be... but it's not working:
Dim AcadDoc As Document = Application.DocumentManager.MdiActiveDocument
AcadDoc.Path? or GetPath?
Slowly learning... thanks for the help.
eric
Active Contributor
1 Kudo
Post 2 of 13
Re: ThisDrawing.Path equivalent
01-05-2010 07:41 AM in reply to: aielli
In C# i did it this way:
AcadApplication oAcadApp = (AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
String sFilePath = oAcadApp.ActiveDocument.Path + "\\" + oAcadApp.ActiveDocument.Name;
so, In VB.NET I think it would be like this:
Dim oAcadApp as AcadApplication
Dim sFilePath as String
Set oAcadApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
sFilePath = oAcadApp.ActiveDocument.Path & "\" & oAcadApp.ActiveDocument.Name;
The path is only the path and the name is only the name.
Active Contributor
0 Kudos
Post 3 of 13
01-05-2010 11:03 AM in reply to: aielli
Thanks, but I don't believe that ActiveDocument is a property of AcadApplication.
I'm using AutoCAD 2010... not sure if this has changed...
*Expert Elite*
37 Kudos
Post 4 of 13
01-05-2010 11:24 AM in reply to: aielli
This works in 2010
{code}
Dim oAcadApp As Autodesk.AutoCAD.ApplicationServices.Document
oAcadApp = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
MsgBox(oAcadApp.Name)
{code}
(defun botsbuildbots() (botsbuildbots))
Active Contributor
0 Kudos
Post 5 of 13
01-05-2010 11:52 AM in reply to: aielli
Thank you!
Didn't realize that the Name property gave the full path.
*Expert Elite*
253 Kudos
Post 6 of 13
01-05-2010 12:05 PM in reply to: aielli
AcadDoc.Name was the reply I gave in your duplicated post:
http://discussion.autodesk.com/forums/thread.jspa?threadID=757438&tstart=0
Yes it is, but DeanLyon is using COM interop rather than .NET API
Gilles Chanteau
*Expert Elite*
37 Kudos
Post 7 of 13
01-05-2010 10:48 PM in reply to: aielli
As mentioned above, This works with COM in 2010
{code}
Dim oAcadApp As Autodesk.AutoCAD.Interop.AcadApplication
Try
oAcadApp = GetObject(, "AutoCAD.Application.18")
Dim sFilePath As String
MsgBox(sFilePath)
Catch ex As Exception
oAcadApp = Nothing
End Try
{code}
Valued Contributor
0 Kudos
Post 8 of 13
01-13-2011 08:04 AM in reply to: aielli
Is there an equivalent for the .path for the .NET API? I don't have COM installed :smileyhappy: I'm looking for it a couple days now but can't find a way to do it.
Active Contributor
1 Kudo
Post 9 of 13
01-13-2011 09:25 AM in reply to: aielli
Whoa -- no need for COM.
Document doc = Application.DocumentManager.MdiActiveDocument;
string path = Path.GetDirectoryName(doc.Database.Filename);
Distinguished Mentor
91 Kudos
Post 10 of 13
01-13-2011 12:15 PM in reply to: aielli
What about the "DWGPREFIX" system variable, it's easy to check in both .NET and COM interop.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
