.NET
Valued Contributor
RPeter
Message 11 of 13 (242 Views)
Re: ThisDrawing.Path equivalent
01-13-2011 10:49 PM in reply to: aielli
dan.glassman => thx man!
New Member
johnel48
Message 12 of 13 (141 Views)
12-31-2011 03:35 PM in reply to: aielli
<CommandMethod("Test1")>
Public Sub Test1()
Dim path As string = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.Filename.ToString
If Right(path,3) <> "dwg" then
MsgBox("This file has not been saved")
Else
MsgBox("ThisDrawing = " & path)
End If
Dim NewPath As String = Left(path, Len(path)-3) & "dat"
MsgBox(NewPath)
End Sub
Member
beeb.pm.Net
Message 13 of 13 (114 Views)
01-07-2012 09:59 PM in reply to: aielli
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Public Shared ReadOnly Property ThisDrg() As AcadDocument
        Get
            Return Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument
        End Get
    End Property
   Public Shared Function GetPath(ByVal ThisDrg As AcadDocument) As String
        Dim strPath As String = ThisDrg.FullName
        strPath = IO.Path.GetDirectoryName(strPath)
        Return strPath
    End Function
