.NET
ThisDrawing.Path equivalent
12 REPLIES 12
Message 1 of 13
aielli
2284 Views, 12 Replies
What's the equivalent of ThisDrawing.Path in VB.NET?
Here's what I think it should be... but it's not working:
Dim AcadDoc As Document = Application.DocumentManager.MdiActiveDocument
AcadDoc.Path? or GetPath?
Slowly learning... thanks for the help.
eric
12 REPLIES 12
Message 2 of 13
deanlyon
in reply to: aielli
In C# i did it this way:
AcadApplication oAcadApp = (AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
String sFilePath = oAcadApp.ActiveDocument.Path + "\\" + oAcadApp.ActiveDocument.Name;
so, In VB.NET I think it would be like this:
Dim oAcadApp as AcadApplication
Dim sFilePath as String
Set oAcadApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
sFilePath = oAcadApp.ActiveDocument.Path & "\" & oAcadApp.ActiveDocument.Name;
The path is only the path and the name is only the name.
Message 3 of 13
aielli
in reply to: aielli
Thanks, but I don't believe that ActiveDocument is a property of AcadApplication.
I'm using AutoCAD 2010... not sure if this has changed...
Message 4 of 13
arcticad
in reply to: aielli
This works in 2010
{code}
Dim oAcadApp As Autodesk.AutoCAD.ApplicationServices.Document
oAcadApp = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
MsgBox(oAcadApp.Name)
{code}
(defun botsbuildbots() (botsbuildbots))
Message 5 of 13
aielli
in reply to: aielli
Thank you!
Didn't realize that the Name property gave the full path.
Message 6 of 13
_gile
in reply to: aielli
AcadDoc.Name was the reply I gave in your duplicated post:
http://discussion.autodesk.com/forums/thread.jspa?threadID=757438&tstart=0
Yes it is, but DeanLyon is using COM interop rather than .NET API
Gilles Chanteau
GileCAD
GitHub
Message 7 of 13
arcticad
in reply to: aielli
As mentioned above, This works with COM in 2010
{code}
Dim oAcadApp As Autodesk.AutoCAD.Interop.AcadApplication
Try
oAcadApp = GetObject(, "AutoCAD.Application.18")
Dim sFilePath As String
MsgBox(sFilePath)
Catch ex As Exception
oAcadApp = Nothing
End Try
{code}
Message 8 of 13
RPeter
in reply to: aielli
Is there an equivalent for the .path for the .NET API? I don't have COM installed 🙂 I'm looking for it a couple days now but can't find a way to do it.
Message 9 of 13
dan.glassman
in reply to: aielli
Whoa -- no need for COM.
Document doc = Application.DocumentManager.MdiActiveDocument;
string path = Path.GetDirectoryName(doc.Database.Filename);
Message 10 of 13
hgasty1001
in reply to: aielli
What about the "DWGPREFIX" system variable, it's easy to check in both .NET and COM interop.
Message 11 of 13
RPeter
in reply to: aielli
dan.glassman => thx man!
Message 12 of 13
johnel48
in reply to: aielli
<CommandMethod("Test1")>
Public Sub Test1()
Dim path As string = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.Filename.ToString
If Right(path,3) <> "dwg" then
MsgBox("This file has not been saved")
Else
MsgBox("ThisDrawing = " & path)
End If
Dim NewPath As String = Left(path, Len(path)-3) & "dat"
MsgBox(NewPath)
End Sub
Message 13 of 13
beeb.pm.Net
in reply to: aielli
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Public Shared ReadOnly Property ThisDrg() As AcadDocument
        Get
            Return Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument
        End Get
    End Property
   Public Shared Function GetPath(ByVal ThisDrg As AcadDocument) As String
        Dim strPath As String = ThisDrg.FullName
        strPath = IO.Path.GetDirectoryName(strPath)
        Return strPath
    End Function
”Boost
