.NET
there any Event when The enhanced properties editor dialogue show out
6 REPLIES 6
kevinsir
493 Views, 6 Replies
Is there any Event when The enhanced properties editor dialogue  show out? I want to do something when the dialogue
is showing.
I first use the CommandWillStart Event to catch the "EATTEDIT" order ,however,if only covers the condition that users doubleClick the block .when users first input EATTEDIT command then select the block this event was wrong! Anyone who can help me? Thanks
6 REPLIES 6
is showing.
What is 'wrong' about the event?  Are you saying your event handler isn't called?
Hallex
in reply to: kevinsir
Take a look at this article
http://drive-cad-with-code.blogspot.ru/2013/03/update-custom-double-click-action-using.html
I mean that is there any new event that i do not know!
kevinsir
in reply to: Hallex
I am sorry that I can not open this url
Hallex
Then read this topic
http://forums.autodesk.com/t5/NET/Run-command-on-double-click-block-with-specific-name/m-p/3790442/h...
kevinsir
in reply to: Hallex
thanks first ,I will try it
”Boost
