.NET
The module was expected to contain an assembly manifest.
1 REPLY 1
SRSDS
21997 Views, 1 Reply
Can anyone explain this error when trying to NETLOAD a compiled dll. It's on a Windows 7 machine running 2009.
Cannot load assembly. Error details: System.BadImageFormatException: Could not
load file or assembly 'file:///C:\Program Files\Profile\Profile .NET3.0.dll' or
one of its dependencies. The module was expected to contain an assembly
manifest.
File name: 'file:///C:\Program Files\Profile\Profile .NET3.0.dll'
  at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase,
Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark,
Boolean throwOnFileNotFound, Boolean forIntrospection)
   at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef,
Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
   at System.Reflection.Assembly.LoadFrom(String assemblyFile)
   at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
   at loadmgd()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value
[HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure
logging.
To turn this feature off, remove the registry value
[HKLM\Software\Microsoft\Fusion!EnableLog].
1 REPLY 1
SRSDS
in reply to: SRSDS
I'm not sure which of these fixed this but..
There were a few reference dll files that I failed to bundle in with the project. Most likely the problem.
I also cleaned the project which was one suggestion I found. Build>Clean
”Boost
