.NET
Valued Contributor
kevinsir
Message 1 of 12 (398 Views)
The layer properties has been set to visible, but layers still can't see
398 Views, 11 Replies
10-10-2012 02:07 AM
I have a problem! When I   load a dwg file, i  set  all invisible layers  to  visible!The layer properties has been set to visible, but the entities on   those invisible layers still can't see。 After that I change the layout,just change the 'model' to 'layout1' Then change  back to 'model' . All entities is visible!
I mean what's the matter with that and  how I can Solve the problem?
private void AddNewLayer(Document doc)
            if (doc.IsReadOnly)
                return;
            using (DocumentLock m_DocumentLock = doc.LockDocument())
                string name = doc.Name;
                using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
                    LayerTable lt = (LayerTable)tr.GetObject(doc.Database.LayerTableId, OpenMode.ForWrite);
                    SymbolTableEnumerator symbolTableEnumerator = lt.GetEnumerator();
                    LayerTableRecord activerecord = null;
                    while (symbolTableEnumerator.MoveNext() == true)
                        ObjectId objEntr = (ObjectId)symbolTableEnumerator.Current;
                        LayerTableRecord ltr = (LayerTableRecord)tr.GetObject(objEntr, OpenMode.ForWrite);
                        if (ltr.IsOff)
                            ltr.IsOff = false;
                    tr.Commit();
Thanks for all replies! I have solved my problem。 All of this is that the doc is not the activedocument! When I Set DocuemntCollection.ActiveDocument=Doc
khoa.ho
Message 2 of 12 (380 Views)
Re: The layer properties has been set to visible, but layers still can't see
10-10-2012 07:37 AM in reply to: kevinsir
After commit transaction, call doc.Editor.UpdateScreen() to update their visibility, doc.Editor.Regen() also updates visibility but slower as it will regenerate all entities.
From AutoCAD .NET documentation:
"The UpdateScreen method redraws the application or document windows. The Regen method regenerates the graphical objects in the drawing window, and recomputes the screen coordinates and view resolution for all objects. It also re-indexes the drawing database for optimum display and object selection performance."
-Khoa
Valued Mentor
DiningPhilosopher
Message 3 of 12 (360 Views)
10-10-2012 01:00 PM in reply to: kevinsir
First, You should be using the TransactionManager of the Document, rather than it's Database (yes, there is a difference).  For updating entities on the affected layers, you can call the RegenLayers() method of the Autodesk.AutoCAD.Internal.LayerUtilities class, and pass it the ObjectIds of the layers you want to regenerate which can be faster than a full regen.
UpdateScreen() will not help here, BTW.
Valued Contributor
kevinsir
Message 4 of 12 (348 Views)
10-10-2012 04:44 PM in reply to: DiningPhilosopher
Thanks for all! I try it ,but i am sorry it is not work.
When I change the mode now, it is also not work. However I click the 'Freezing new view' button on layer  edit dialog then apply it, It is work now.It makes me very confusing!
Valued Contributor
kevinsir
Message 5 of 12 (339 Views)
10-10-2012 07:23 PM in reply to: kevinsir
I just input 'regen' command in editor,but it is not work !
Hallex
Message 6 of 12 (329 Views)
10-10-2012 10:43 PM in reply to: kevinsir
Try this command:
<DllImport("acad.exe", EntryPoint:="?applyCurDwgLayerTableChanges@@YA?AW4ErrorStatus@Acad@@XZ")> _ Private Shared Sub applyCurDwgLayerTableChanges() End Sub
then at the end of your directive add this line:
~'J'~
Valued Contributor
kevinsir
Message 7 of 12 (320 Views)
10-11-2012 12:24 AM in reply to: Hallex
I use your method it is also not work。It get the error message of  ‘can not  find '?' entrypoint’
Mybe I find the reason,When I Execute the above AddNewLayer function, doc is not the activeDocument because it is starting。 So when I execute the doc.Editor.UpdateScreen() It is also get the error.
Valued Contributor
kevinsir
Message 8 of 12 (317 Views)
10-11-2012 12:50 AM in reply to: DiningPhilosopher
I'm using AutoCAD 2008,and i have not find the Autodesk.AutoCAD.Internal.LayerUtilities class!
Valued Contributor
kevinsir
Message 9 of 12 (311 Views)
10-11-2012 01:51 AM in reply to: Hallex
Valued Mentor
DiningPhilosopher
Message 10 of 12 (256 Views)
10-13-2012 07:52 PM in reply to: kevinsir
The document you're modifying must be the active document or all bets are off
