.NET
The biggest problems in the managed ObjectARX
10 REPLIES 10
Message 1 of 11
530 Views, 10 Replies
1.Menu
2.Toolbar
3.Selectionset(multiple select)
10 REPLIES 10
Message 2 of 11
My biggest....people refereing to managed ObjectARX!!! Drop the ObjectARX
as .NET and it are two different beasts.
-- Mike
___________________________
Mike Tuersley
the trick is to realize that there is no spoon...
Message 3 of 11
>> Drop the ObjectARX as .NET and it are two different beasts.
No, they're not two different beasts. There are some
differences, but they are more alike than they are
different. The fact of the matter is that the managed
wrappers for ObjectARX require some understanding of
ObjectARX.
The only problem here is that the hill may be a bit too
steep for some of you VB 'programmers', but spinning
that as something other than what it is, isn't going to
get you much sympathy from most ObjectARX types.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
Message 4 of 11
If this is all the logic we need for ARX than I'm
all set....;)
"Tony Tanzillo" wrote in message
news:4851193@discussion.autodesk.com...
ObjectARX.
Message 5 of 11
> ObjectARX.
So managed ObjectARX question would be best served by the ObjectARX group? I
think that's what Mike was driving at.
Message 6 of 11
Hi there,
This is a bit terse. Can you elaborate? What do you perceive as a problem
here?
Albert
wrote in message news:4850204@discussion.autodesk.com...
1.Menu
2.Toolbar
Message 7 of 11
ObjectARX programmers also must use the COM
API for accessing toolbars and menus. Not sure
what you mean by third item. What have you found
lacking?
1.Menu
2.Toolbar
Message 8 of 11
Thanks, yes, that's my point. Poor choice of wording on my part.
-- Mike
Mike Tuersley
Message 9 of 11
Correct me if I am wrong, but there is no ObjectARX.NET There is ObjectARX
and there is the managed .NET libraries. You can do ObjectARX dev or
C++.NET/VB.NET/C#.NET dev
-- Mike
Mike Tuersley
Message 10 of 11
Oh, and my choice of wording about being "different beasts" was poorly
conceived.My point is we have OUR group now and there remains the ObjectARX
group 😃
-- Mike
Mike Tuersley
Message 11 of 11
I have found the method to solve the problems(menu and toolbar,but not multiple selectionset )! I will give some example soon.
”Boost
