.NET
Text Justification
3 REPLIES 3
BrentBurgess1980
927 Views, 3 Replies
Text Justification
I am setting my DBText's justification, and I cannot seem to set it to Top Centre (defaults back to BaseAlign). All of the others seem to work. I have attached an image.
Am I missing something obvious?
3 REPLIES 3
You might try the AdjustAlignment method of the DBText object after you've set its new justification and Alignment point.
Something like this?
Me.Text.AdjustAlignment.(Autodesk.AutoCAD.DatabaseServices.HostApplicationServices.WorkingDatabase);
at one time I had a problem with a certain justification, (I don't recall if it was TopCenter or not) I found that the only thing that seemed to work was to set the HorizontalMode and VerticalMode properties, instead of Justify.
tyronebk
in reply to: chiefbraincloud
Thanks ChiefBrainCloud.
Also, the TopCenter attachment point was only failing for me if the DBText object was annotative.
”Boost
