.NET
9 Kudos
Post 1 of 4
Text Justification
714 Views, 3 Replies
09-01-2010 10:08 PM
I am setting my DBText's justification, and I cannot seem to set it to Top Centre (defaults back to BaseAlign). All of the others seem to work. I have attached an image.
Am I missing something obvious?
Active Member
0 Kudos
Post 2 of 4
Re: Text Justification
09-02-2010 05:24 AM in reply to: BrentBurgess1980
You might try the AdjustAlignment method of the DBText object after you've set its new justification and Alignment point.
Something like this?
Me.Text.AdjustAlignment.(Autodesk.AutoCAD.DatabaseServices.HostApplicationServices.WorkingDatabase);
54 Kudos
Post 3 of 4
09-02-2010 10:48 AM in reply to: BrentBurgess1980
at one time I had a problem with a certain justification, (I don't recall if it was TopCenter or not) I found that the only thing that seemed to work was to set the HorizontalMode and VerticalMode properties, instead of Justify.
26 Kudos
Post 4 of 4
06-07-2011 02:57 PM in reply to: chiefbraincloud
Thanks ChiefBrainCloud.
Also, the TopCenter attachment point was only failing for me if the DBText object was annotative.
