.NET
Temporary Line
2 REPLIES 2
joshua.prettyman
1102 Views, 2 Replies
Temporary Line
I'm working on a little command that would be really nice to have a temporary line drawn between some points while you're picking them.  Something akin to the little line that's drawn in the Measure Distance command.  The thing is, I don't really know what this is... can anybody point me in the right direction?
2 REPLIES 2
kdub_nz
in reply to: joshua.prettyman
If I understand correctly you want a rubberband line whwn selecting the second point.
In the PromptPointOptions set
 .UseBasePoint = true;
 .BasePoint = firstPoint;
see if that helps.
Regards
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
joshua.prettyman
in reply to: kdub_nz
Sorry for the wait, I thought I'd checked this but apparently it didn't catch.  That solution was exactly what I was looking for, thanks.
”Boost
