.NET
Active Contributor
M_Mogharabi
Message 1 of 2 (145 Views)
template unit
145 Views, 1 Replies
02-07-2012 12:27 AM
hi everyone.
 I specify a template when I open a new auotocad file and drawi  some shapes in autocad with c#.
the problem is the coordinates that I use to draw shapes does not match the template file and therefore the shapes are misplaced.(I am using centimeters for my code).
how can I change the coordinate of the template file to match my code coordinate?
thanks in advance.
Valued Mentor
fieldguy
Message 2 of 2 (124 Views)
Re: template unit
02-07-2012 08:14 AM in reply to: M_Mogharabi
You have to create and use a new template.  The easiest way IMO is to open a drawing that is correct, delete all of the objects and purge (keep the existing layers and styles if you want) and SAVEAS with a DWT extension.
Templates are DWG files with a DWT extension.
