.NET
Take point of line by VB.net
6 REPLIES 6
1776 Views, 6 Replies
Hi All,
I have ever post a topic related to this post.
"hi All,
I have a difficult problem. This is, how can i determine width of a square when i click inside it. And i have attach file autocad.
And i have do the same suggestion of @zrobert  And success. But I can not apply for file autocad(I have attach) . In my file Autocad have a lot of squares( each square have number) and a lot of layer. Anybody can help me solve this problem. Thank very much.
6 REPLIES 6
I think it really difficult. very very difficult.
hgasty1001
It's not a very difficult problem, as start try with boundary trace, this link may help you: Find Loop
Gaston Nunez
in reply to: hgasty1001
Thanks very much. But do u have another link. Because i write by vb.net. If don't have i will try translate it to vb.net.
ChaosInACT
I've had to pick up c++ for this last project AND expand my vb among other things - so I'm NOT learning c# either right now!!! That's why I use the c# to Vb.net online converters since so many examples are in c# -- it works very well....any (small) mistakes it makes you should be able to easily see - it often helps you under stand it better even 😄
hgasty1001
Try the online converters here:Telerik and here:DeveloperFusion both are pretty good, take care events in C# , as they doesn't translate the " =+" sintax to vb.
Gaston Nunez
Mình xin cảm ơn các bạn.
”Boost
