.NET
Table Flow Direction
4 REPLIES 4
cadcamm99
1090 Views, 4 Replies
I tried to use the command: tablestyle.FlowDirection = FlowDirection.BottomToTop when defining the table style but that did not work.
Then I used table.FlowDirection = FlowDirection.BottomToTop when defining the table but that did not work also.
Any other ideas?
4 REPLIES 4
in reply to: cadcamm99
1.  Committing your transaction?
2.  In the old day, tables were ripped out of the NOD and then loaded into a table class object by the ID with a trans.getobject, perhaps you don't have a proper instance of the table.
cadcamm99
I just found out I have to use an integer instead.  tablestyle.flowdirection = 0 (for down) or 1 (for up).
deltacadd
You should also cast the integer to FlowDirection, as in:
tablestyle.FlowDirection = (FlowDirection) 1; // For BottomToTop
or
table.FlowDirection = (FlowDirection) 1;
Hope this helps someone.
rui143
You can set the tablestyle like
TableStyle ts = new TableStyle();
ts.FlowDirection = (FlowDirection)1;    //Buttom to Up
”Boost
