.NET
Tab merge partial cui
1 REPLY 1
Fredrik.Larsen
769 Views, 1 Reply
Hi
I have created a partial cui file that creates a new tab and a panel in the tab. This works fine.
When I try to create another cui for another plug-in I cannot get the two tabs to merge. I have set the tab Aliases to be the same but they show up as two tabs next to eachother.
Any ideas?
Tags (3)
1 REPLY 1
Balaji_Ram
in reply to: Fredrik.Larsen
Hi Fredrik,
AutoCAD does not merge tabs from partial CUI.
Only tabs in the main cui are considered by AutoCAD for merging based on their alias.
This post might be of some help :
http://forums.autodesk.com/t5/AutoCAD-2011/common-ribbontab-in-different-partial-cui/td-p/3408299
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
