.NET
System.AccessViolationException: Attempted to read or write protected memory.
12 REPLIES 12
Message 1 of 13
xpeter88
18670 Views, 12 Replies
Hi all,
I finished one code that opens the drawings does some changes in block tables and saves the updated drawings. Everything works perfectly as it should except this one error that I cannot figure out.
netload -> run my app -> it finishes -> and now when I close AutoCAD Application it gives me this error -> always the same and when I close AutoCAD App only.
Do you have any ideas where could be problem? Using AutoCAD 2012 and MS Visual Studio 2010.
Seems like something is still in memory and after I close AutoCAD app it tries to release from it.
Have you seen it before? Cannot identify where the issue starts as this message does not appear when I run the code.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
   at Autodesk.AutoCAD.DatabaseServices.Transaction.CheckTopTransaction()
   at Autodesk.AutoCAD.DatabaseServices.Transaction.DeleteUnmanagedObject()
   at Autodesk.AutoCAD.Runtime.DisposableWrapper.!DisposableWrapper()
   at Autodesk.AutoCAD.Runtime.DisposableWrapper.Dispose(Boolean )
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 3.2.23.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AdApplicationFrame.DLL
Acdbmgd
    Assembly Version: 18.2.0.0
    Win32 Version: 18.2.51.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcdbMgd.DLL
System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
msvcm90
    Assembly Version: 9.0.30729.8387
    Win32 Version: 9.00.30729.8387
    CodeBase: file:///C:/WINDOWS/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5/msvcm90.dll
AdWindows
    Assembly Version: 3.2.25.0
    Win32 Version: 3.2.25.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AdWindows.DLL
PresentationFramework
    Win32 Version: 4.0.30319.34004
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
    Win32 Version: 4.0.30319.34004 built by: FX45W81RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Aero2
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Acmgd
    Win32 Version: 18.2.205.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/Acmgd.DLL
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcWindows.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcCui.DLL
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
PresentationFramework-SystemXml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
WindowsFormsIntegration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/en-US/AcWindows.resources.DLL
ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcWindows.dll
System.Windows.Forms
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
ManagedMC3
    Assembly Version: 5.8.0.0
    Win32 Version: 5.8.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/ManagedMC3.DLL
PresentationFramework-SystemCore
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
UIAutomationTypes
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
PresentationFramework.Luna
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcWelcomeScreen
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcWelcomeScreen.DLL
AcMrUi
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcMrUI.DLL
AcMrUi.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/en-US/AcMrUi.resources.DLL
AcMr
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcMr.DLL
System.Runtime.Serialization
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
AcLayer
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcLayer.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/en-US/AcLayer.resources.DLL
AcButterflyExt
    Assembly Version: 1.0.0.23
    Win32 Version: 1.0.0.23
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcButterflyExt.DLL
AcButterflyExt.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/en-US/AcButterflyExt.resources.DLL
UIAutomationProvider
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
AcCommandToolTips
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcCommandToolTips.DLL
AcCommandToolTips.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/en-US/AcCommandToolTips.resources.DLL
Connect.Client.AutoCAD
    Assembly Version: 2.0.90.0
    Win32 Version: 2.0.90.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/Connect.Client.AutoCAD.DLL
ATTRIBUTE_CHANGER
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/Gigo/Documents/Visual%20Studio%202010/Projects/ATTRIBUTE_CHANGER/ATTRIBUTE_CHANGER/bin/Debug/ATTRIBUTE_CHANGER.dll
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 12.0.20806.33440 built by: FX45W81RTMREL
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Microsoft.Office.Interop.Excel
    Assembly Version: 15.0.0.0
    Win32 Version: 15.0.4420.1017
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.Office.Interop.Excel/15.0.0.0__71e9bce111e9429c/Microsoft.Office.Interop.Excel.dll
office
    Win32 Version: 15.0.4551.1009
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/office/15.0.0.0__71e9bce111e9429c/office.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
12 REPLIES 12
Message 2 of 13
3dmathe2sowmin
in reply to: xpeter88
hi
i am interpreting the error as System.AccessViolation is of as guessed memory that is not free during closure of program. for get going i came out with fear for text as line. Area to look at
System.Permission, some folder settings change as i could think of.
Tags (1)
Message 3 of 13
hgasty1001
This ATTRIBUTE_CHANGER.dll is my main suspect, i guess it's not disposing attributes references.
Gaston Nunez
Message 4 of 13
xpeter88
in reply to: hgasty1001
I am using this for attribute definitions
Dim acAttDef As AttributeDefinition = acTrans.GetObject(acEntity.ObjectId, OpenMode.ForWrite)
some oprerations here
and acAttDef.Dispose is there as well for attribute definitions.
If you mean this..
Do you think that the issue with the disposing objects?
Message 5 of 13
hgasty1001
Only guessing...without code to inspect.
Gaston Nunez
Message 6 of 13
hgasty1001
Not sure what are you trying to do, but if you aim is to set attributes values, you don't have to open for write the attributes definition. This is a way to go with attributes:
Public Shared Sub SetAttValue(ByVal blkRef As BlockReference, ByVal attributeTag As String, ByVal AttValueAs String, ByVal tr As Transaction)
        Dim btr As BlockTableRecord = DirectCast(tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
        For Each attId As ObjectId In btr
            Dim ent As Entity = DirectCast(tr.GetObject(attId, OpenMode.ForRead), Entity)
            If TypeOf ent Is AttributeDefinition Then
                Dim attDef As AttributeDefinition = DirectCast(ent, AttributeDefinition)
                Dim attRef As New AttributeReference()
                attRef.SetAttributeFromBlock(attDef, blkRef.BlockTransform)
                If attRef.Tag = attributeTag.ToUpper Then
                    attRef.TextString = AttValue
                    Dim id As ObjectId = blkRef.AttributeCollection.AppendAttribute(attRef)
                    tr.AddNewlyCreatedDBObject(attRef, True)
                attRef.Dispose()
        Next
    End Sub
 Gaston Nunez
Message 7 of 13
xpeter88
in reply to: 3dmathe2sowmin
 @3dmathe2sowmin: I did not get you at all
Message 8 of 13
xpeter88
Gasty, I don't think I am doing this wrong check this.
I am not updating attribute references of blocks but values of attribute definitions that are not nested in blocks based on it's tag.
Using acTrans As Transaction = acNewDwgDb.TransactionManager.StartTransaction()
                                        Dim acBlkTbl As BlockTable = acTrans.GetObject(acNewDwgDb.BlockTableId, OpenMode.ForRead)
                                        Dim acBlkTblRec As BlockTableRecord = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                                        Dim acObjId As ObjectId
                                        For Each acObjId In acBlkTblRec
                                            Dim acEntity As Entity = acTrans.GetObject(acObjId, OpenMode.ForWrite)
                                            If (TypeOf acEntity Is AttributeDefinition) Then
                                                If acAttDef.Tag.ToUpper = AttributeTag Then
                                                    acAttDef.UpgradeOpen()
                                                    If acAttDef.IsWriteEnabled = True Then
                                                            acAttDef.TextString = AttributeValue
                                                    acEntity.Dispose()
                                        Next
                                        acTrans.Commit()
                                        acTrans.Dispose()
                                    End Using
Message 9 of 13
mzakiralam
Hi ,
don't dispose transaction before end using. With end using transaction will be disposed automatically. first you have disposed the transaction and at the end of end using, it is trying to dispose transaction again. just remove the  line "acTrans.Dispose()" and try again with your code.
Message 10 of 13
3dmathe2sowmin
Firstly i vaguely understood System.AccessViolationException as attempt to read or write data in the memory location that is not meant for a particular user. so in my particular thread i asked as small suggestion that could point you to look at permission to read-write data in network tab.
Message 11 of 13
xpeter88
in reply to: mzakiralam
@mzakiralam: thanks, I did not know that as I am quite new to the .net. I will remember that and try it out as soon as I get home. I've just posted the "core", it is not all I have, there is open folder dialog, reading excel file, writes some text files etc etc, I will check it all if I did not make this misstake somewhere else too and let you know here.
Message 12 of 13
xpeter88
Checked my code and to remove acTrans.Dispose() did not help at all. There no more cases like this.
Can be the problem with some of the referenced *.dll's? I have a similar code that is mostly the same like this - no special differences just less references and works fine.
Message 13 of 13
xpeter88
Public Class MyCommands
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
        <CommandMethod("myspecialcommand")>
This was the issue between the class and commendmethod.... probably did a copy paste misstake and did not see it in in all the lines of code.
”Boost
