.NET
.NET
Valued Contributor
3 Kudos
Post 1 of 14
synchronicity, friends, & acedcommand
1853 Views, 13 Replies
04-20-2012 08:21 AM
I had a VBA routine that worked using SENDCOMMAND.
my VB.NET version does not work using SENDCOMMAND (well, it does work, just not at the right time).
I've looking into the problem I have found that SENDCOMMAND is asynchronous in the document context but not in the application context. What does that mean? There is document.editor.SENDCOMMAND, but no application.SENDCOMMAND (or is there?).
So I tried using acedcommand (&/or acedcmd) but i'm getting an IDE error saying "AcEdCommand' is not accessible in this context because it is 'Friend' "
what is the proper syntax or methodology for using acedcommand?
I agree.
By my side, to get some beers at the store, I'd rather use AutoLISP with which you can easily script native commands.
Anyway, here's a little helper to use acedCmd with managed code (inspired by Tony Tanzillo's CommandLine (thanks again to him).
The Command method build the resultbuffer with the passed arguments.
EDIT: with A2013, replace "acad.exe" with "accore.dll" in the DllImport attribute arguments.
C#
 [System.Security.SuppressUnmanagedCodeSecurity]
[DllImport("acad.exe", EntryPoint = "acedCmd",
CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl)]
extern static private int acedCmd(IntPtr resbuf);
/// <summary>
/// Call an AutoCAD command (runs synchronously).
/// </summary>
/// <param name="args">The command name followed by command inputs.</param>
public static void Command(params object[] args)
ResultBuffer resbuf = new ResultBuffer();
foreach (object obj in args)
switch (obj.GetType().Name)
case "String":
resbuf.Add(new TypedValue((int)LispDataType.Text, obj)); break;
case "Int16":
resbuf.Add(new TypedValue((int)LispDataType.Int16, obj)); break;
case "Int32":
resbuf.Add(new TypedValue((int)LispDataType.Int32, obj)); break;
case "Double":
resbuf.Add(new TypedValue((int)LispDataType.Double, obj)); break;
case "Point2d":
resbuf.Add(new TypedValue((int)LispDataType.Point2d, obj)); break;
case "Point3d":
resbuf.Add(new TypedValue((int)LispDataType.Point3d, obj)); break;
case "ObjectId":
resbuf.Add(new TypedValue((int)LispDataType.ObjectId, obj)); break;
case "ObjectId[]":
foreach (ObjectId id in (ObjectId[])obj)
resbuf.Add(new TypedValue((int)LispDataType.ObjectId, id));
break;
case "ObjectIdCollection":
foreach (ObjectId id in (ObjectIdCollection)obj)
break;
case "SelectionSetDelayMarshalled":
case "SelectionSetFullyMarshalled":
resbuf.Add(new TypedValue((int)LispDataType.SelectionSet, obj)); break;
default:
throw new InvalidOperationException("Unsupported type in Command() method");
acedCmd(resbuf.UnmanagedObject);
 VB
 <System.Security.SuppressUnmanagedCodeSecurity()> _
<DllImport("acad.exe", EntryPoint:="acedCmd", CharSet:=CharSet.Unicode, CallingConvention:=CallingConvention.Cdecl)> _
Private Shared Function acedCmd(resbuf As IntPtr) As Integer
End Function
'''<summary>
''' Call an AutoCAD command (runs synchronously).
''' </summary>
''' <param name="args">The command name followed by command inputs.</param>
Public Shared Sub Command(ParamArray args As Object())
Dim resbuf As New ResultBuffer()
For Each obj As Object In args
Select Case obj.GetType().Name
Case "String"
resbuf.Add(New TypedValue(CInt(LispDataType.Text), obj))
Exit Select
Case "Int16"
resbuf.Add(New TypedValue(CInt(LispDataType.Int16), obj))
Exit Select
Case "Int32"
resbuf.Add(New TypedValue(CInt(LispDataType.Int32), obj))
Exit Select
Case "Double"
resbuf.Add(New TypedValue(CInt(LispDataType.[Double]), obj))
Exit Select
Case "Point2d"
resbuf.Add(New TypedValue(CInt(LispDataType.Point2d), obj))
Exit Select
Case "Point3d"
resbuf.Add(New TypedValue(CInt(LispDataType.Point3d), obj))
Exit Select
Case "ObjectId"
resbuf.Add(New TypedValue(CInt(LispDataType.ObjectId), obj))
Exit Select
Case "ObjectId[]"
For Each id As ObjectId In DirectCast(obj, ObjectId())
resbuf.Add(New TypedValue(CInt(LispDataType.ObjectId), id))
Next
Exit Select
Case "ObjectIdCollection"
For Each id As ObjectId In DirectCast(obj, ObjectIdCollection)
Next
Exit Select
Case "SelectionSetDelayMarshalled", "SelectionSetFullyMarshalled"
resbuf.Add(New TypedValue(CInt(LispDataType.SelectionSet), obj))
Exit Select
Case Else
Throw New InvalidOperationException("Unsupported type in Command() method")
End Select
Next
End Sub
Using examples (VB):
Draws a line.
Command("_.line", New Point3d(10.0, 20.0, 0.0), New Point3d(80.0, 50.0, 0.0), "")
 Freezes the "0" layer in the selected viewport.
Command("_.vplayer", "_freeze", "0", "_select", "\", "", "")
 Note:
- an empty string ("") means a validation (Enter)
- an anti-slash ("\" with VB or "\\" with C#) means a pause for user input.
Moderator
277 Kudos
Post 2 of 14
Re: synchronicity, friends, & acedcommand
04-20-2012 10:09 AM in reply to: kcimos
Synchronously Send (and wait for) commands in AutoCAD using C# .NET
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
3 Kudos
Post 3 of 14
04-20-2012 11:11 AM in reply to: kcimos
Thanks for the link, but my C knowledge is very weak, I'm using VB.
what does this do:
private static extern int acedCmd(System.IntPtrvlist);
is it declaring a integer variable named acedcmd? no, not with an arguement.
so is it prototyping a function named acedcmd that has an arguement in the form of a system.intptrvlist type and returns an integer? & the intptrvlist is essentially the list of strings that you want to send?
but isn't acedcmd aldready a function?
Valued Contributor
2 Kudos
Post 4 of 14
04-20-2012 11:23 AM in reply to: kcimos
[DllImport("acad.exe", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedCmd")]
private static extern int acedCmd(System.IntPtr vlist);
 The whole of the above is the code needed for PInvoke of acedCmd.  The attribute (stuff between []) is the import of the command and it decorates the private static extern int acedCmd(System.IntPtr vlist) so the acedCmd is available in your code.
The System.IntPtr vlist is actually a result buffer that is created a few lines below:
ResultBuffer rb = new ResultBuffer();
  // RTSTR = 5005
  rb.Add(new TypedValue(5005, "_.INSERT"));
  // start the insert command
  acedCmd(rb.UnmanagedObject);
After you have the PInvoke and extern declared you can use the acedCmd as above, the result buffer holds a string (code 5005) and in this case the string is the insert command.  This is how the acedCmd is used, you cant just send it a string directly, you need to use result buffers.
If you look at the documentation for result buffer you will see the different codes and how they work.  If you google PInvoke you can get more details on how it works and what exactly is going on.
From the documentation the returned int:
The return value of acedCmd() does not indicate the success or failure of a command. The function usually returns RTNORM. It returns RTCAN if the user cancels the command by pressing [Ctrl]+[C] or [Ctrl]+[Break]. It returns RTERROR or RTREJ to indicate a failure of undefined origin, not a command failure.
http://docs.autodesk.com/ACDMAC/2012/ENU/ObjectARX%20Reference/index.html?frmname=topic&frmfile=aced...
RTNORM and RTCAN etc are integers defined somewhere else as constants in the ObjectARX files.  Not sure off the top of my head where though.
 One more edit, the private static extern int acedCmd(System.IntPtr vlist)
You see the System.IntPtr vlist in there, and from the documentation above you read:
int acedCmd(const struct resbuf * rbp);
Pointer to a result-buffer list, in which each buffer specifies a data item whose value is passed to AutoCAD as if it were entered at the Command prompt
This is why the System.IntPtr vlist is in the command declaration, the underlying command you are Pinvoke'ing defines it takes a pointer to a result buffer, so this needs to be in the command declaration as it is.
253 Kudos
Post 5 of 14
04-20-2012 11:53 AM in reply to: tonofsteel
IMO, you'd rather try to hard code what the native command do.
Most of the time it's more easy than understanding how to P/invoke unmanaged methods and it's a good way to learn the API.
Gilles Chanteau
Valued Contributor
3 Kudos
Post 6 of 14
04-20-2012 03:18 PM in reply to: kcimos
yeah, looks like I might have to. The thing is that I already have a fully functional VBA routine that has a lot going on. To match the funtionality of VPLAYER, I'm going to have to do a great deal of additional work involving searching layertables & retrieving IDs. Just a lot of extra work to replicate something that already works in VBA. + the viewport object's methods don't cover all of the functinality of VPLAYER, therefore I have to write additional alogorithms to replicate the functionality that my VBA routine provided via VPLAYER.
It is rather irritating.
VB.NET, for me, is like using a jet fighter to go to the store to get some beer instead of using a car (VBA), when you have a car that runs & you know how to drive very well, but someone (microsoft) won't let you drive it anymore.
253 Kudos
Post 7 of 14
04-21-2012 01:08 AM in reply to: kcimos
I agree.
C#
        /// <summary>
        /// </summary>
                    case "String":
                    case "Int16":
                    case "Int32":
                    case "Double":
                    case "Point2d":
                    case "Point3d":
                    case "ObjectId":
                    case "ObjectId[]":
                        break;
                        break;
                    default:
 VB
        End Function
        '''<summary>
        ''' </summary>
                    Case "String"
                        Exit Select
                    Case "Int16"
                        Exit Select
                    Case "Int32"
                        Exit Select
                    Case "Double"
                        Exit Select
                    Case "Point2d"
                        Exit Select
                    Case "Point3d"
                        Exit Select
                    Case "ObjectId"
                        Exit Select
                    Case "ObjectId[]"
                        Next
                        Exit Select
                        Next
                        Exit Select
                        Exit Select
                    Case Else
                End Select
            Next
        End Sub
Draws a line.
 Note:
Gilles Chanteau
Valued Contributor
3 Kudos
Post 8 of 14
04-25-2012 10:30 AM in reply to: kcimos
thank you so much, that works in a very awesome manner.
6 Kudos
Post 9 of 14
06-01-2012 06:14 AM in reply to: kcimos
how can I use LISP functions or custom commands with that Tony's method?
I can't figure that out
253 Kudos
Post 10 of 14
06-03-2012 03:22 AM in reply to: matus.brlit
If you want to run LISP functions, you'd rather use the Application.Invoke() method (A2011 or later) or P/Invoke the unmanaged acedInvoke() method.
Gilles Chanteau
