.NET
Valued Contributor
smccoywm
Message 1 of 6 (396 Views)
SymBBAuto not working in 2014
396 Views, 5 Replies
06-13-2013 06:17 AM
I am trying to call the following line in VB.net but with the release of 2014 this piece of code no longer works.
symbb = odwg.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr.5")
Has anyone else experienced this or now of a fix?
Scott
Problem solved! Thanks to Wayne with AutoDesk. Turns out that when installing Acad 2014 the symBBAuto did not register. Running "AutoCAD 2014 installation path>\Acadm\enu\symbbautoreg.exe" did the trick. Hope this helps if anyone else encounters this problem.
Scott McCoy
Valued Contributor
amanero
Message 2 of 6 (391 Views)
Re: SymBBAuto not working in 2014
06-13-2013 07:13 AM in reply to: smccoywm
Hello Scott,
Have you tried putting an "6" instead of the "5"?
Luis Alberto Manero, Geograma.com
Valued Contributor
smccoywm
Message 3 of 6 (381 Views)
06-13-2013 07:35 AM in reply to: smccoywm
Thank you for the reply. I did try 6. In fact I tried all numbers 1 to 9 and no number works.
Valued Contributor
amanero
Message 4 of 6 (379 Views)
06-13-2013 07:44 AM in reply to: smccoywm
I'm not sure but, have you seen this?
http://adndevblog.typepad.com/manufacturing/2012/07/sometimes-getinterfaceobjectsymbbautomcadsymbolb...
Valued Contributor
smccoywm
Message 5 of 6 (350 Views)
06-14-2013 09:28 AM in reply to: smccoywm
Luis,
Thank you for the link. I tried to follow the instructions but I get the following error that GetInterfaceObject does not exist in AcadmAuto. That call only exists in basic AutoCAD and I cannot get AutoCAD interop to connect to symBBAuto even though I have sucessfully done it that way in the last 5 releases.
mAcmApp = (AcadmApplication)mAcadApp.GetInterfaceObject("AcadmAuto.AcadmApplication.2");
//Get symbol manager
mSymMgr = (McadSymbolBBMgr)mAcadApp.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr.4");
Scott A. McCoy
Valued Contributor
smccoywm
Message 6 of 6 (299 Views)
06-26-2013 01:25 PM in reply to: smccoywm
Scott McCoy
