.NET
Switching between EMEA and NAM standards
0 REPLIES 0
Message 1 of 1
476 Views, 0 Replies
Hi
I'm working on a COM application made in C# that can draw outline of a room and physical units in it. All the equipment in the room is inserted blocks with mm as the default measure.
The app can be run in both NAM and EMEA mode, so I need a smart way to convert my finished drawing to NAM, since it's default EMEA.
I have very little knowledge of AutoCAD functions but has several years of programming knowlegde. So if you could point me to the right Autocad functions / methods or best practices, it would help a lot.
I hope there is a apply to modelspace, which can do everything at once. Or do I actively grab each item, and convert them?
/Peter
0 REPLIES 0
”Boost
