.NET
Swept Solid - Align To Path
1 REPLY 1
Hugh_Compton
355 Views, 1 Reply
I'm trying to create a swept solid that is aligned to its path but the solid appears in a different position to the path.  My code (adapted from though the interface) is attached.
1 REPLY 1
Hugh_Compton
in reply to: Hugh_Compton
I solved this by removing the following line from the code:
 sob.BasePoint = pathEnt.StartPoint
It works well now.
”Boost
