.NET
16 Kudos
Post 1 of 8
Suppress Messages
382 Views, 7 Replies
08-21-2012 11:34 PM
Is there a way to suppress the message boxes given by autocad, such as Drawing file recovery. We are doing a project where this message stops execution of code every time
My current code is using the concept of Latebinding and Multithreading, will this work if i incorporate this logic.
With Warm Regards
Amit
Valued Contributor
1 Kudo
Post 2 of 8
Re: Suppress Messages
08-22-2012 01:19 AM in reply to: amitk_189
hi
with regards to drawing recovery at least, try setting the RECOVERYMODE system variable to 0 or 1:
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a91938...
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html (under 'set and return system variables')
hope this is of use
16 Kudos
Post 3 of 8
08-22-2012 04:49 AM in reply to: amitk_189
But How do i control these issues through code?
With Warm Regards
Amit
Valued Contributor
1 Kudo
Post 4 of 8
08-22-2012 06:30 AM in reply to: amitk_189
sorry if my post wasn't clear or if i missunderstood; based on the section 'set and return system variables' of the developer's guide (2nd link):
Dim nMaxSort as Integer = Application.GetSystemVariable("RECOVERYMODE")
Application.SetSystemVariable("RECOVERYMODE", 1)
as a result, "the Drawing Recovery window does not display automatically" (1st link).
(if what you're looking for is a way of programmatically handling [any] acad messagebox events, say on opening acad, i have to pass)
16 Kudos
Post 5 of 8
08-22-2012 09:09 PM in reply to: amitk_189
With Warm Regards
Amit
171 Kudos
Post 6 of 8
08-23-2012 08:12 AM in reply to: amitk_189
Add this function
    Public Shared Sub SetVar(owner As Object, varname As String, value As Object)
        Dim args As Object() = New Object() {varname, value}
        owner.GetType().InvokeMember("SetVariable", Reflection.BindingFlags.InvokeMethod Or Reflection.BindingFlags.IgnoreCase, _
                        Nothing, _
                        owner, _
                        args)
    End Sub
Then inside your calling Sub add this line
after you have a got activedocument
       AcDoc = AcadApp.GetType.InvokeMember( _
        "ActiveDocument", BindingFlags.GetProperty,
Nothing, AcadApp, Nothing, Nothing)
            SetVar(AcDoc, "regenmode", 1)
Restore variable at the end of work with active document
~'J'~
16 Kudos
Post 7 of 8
08-24-2012 03:12 AM in reply to: amitk_189
Thanks Hallex, this logic resolved the bug.
Thanks a lot Hallex
171 Kudos
Post 8 of 8
08-26-2012 11:24 AM in reply to: amitk_189
You're quietly welcome
Happy coding :smileyhappy:
~'J'~
