.NET
Suppress Dialog Layer - Excess Layer Filters - Dialog Showing Event
3 REPLIES 3
david_rock
837 Views, 3 Replies
Any ideas how I can suppress the dialog "Layer - Excess Layer Filters". I am running a script across hundreds of drawings and many of the drawings launch this dialog. There is no option of always do this option. So I was hoping to find a dialog showing event. Similar to the one in the Revit api.
I know how to erase the layer filters. I am looking to suppress the dialog.
Thanks very much
David
3 REPLIES 3
If you start the command with a leading dash, then the layerdialog will not appear:
_-LAYER
HTH,
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
I don't know about an event, but since you say you are scripting, you can set LAYERFILTERALERT to 0 for no action, or 1, to automatically delete layer filters without prompting.
Excelent, I didn't know the variable LAYERFILTERALER existed.
Thanks very much
David
”Boost
