.NET
Summary Info
6 REPLIES 6
491 Views, 6 Replies
Summary Info
I have captured the "before save" event and created a routine to increment a version property in the document properties.
It appears to work, but the ToDatabaseSummaryInfo does not update the current summary info (I assume that is what the method does)
Am I grossly mislead?
Public Sub IncrementVersionCounter(ByVal o As Object, ByVal e As Autodesk.AutoCAD.DatabaseServices.DatabaseIOEventArgs)
Dim intVersion As Integer
Dim strVersion As String
Dim oOldAcadSummaryInfo As DatabaseSummaryInfo
Dim oNewAcadSummaryInfo As DatabaseSummaryInfo
Dim oAcadDB As Database = Application.DocumentManager.MdiActiveDocument.Database
oOldAcadSummaryInfo = oAcadDB.SummaryInfo
strVersion = oOldAcadSummaryInfo.RevisionNumber
Try
If strVersion = "" Then strVersion = "0"
intVersion = CInt(strVersion)
Catch ex As Exception
intVersion = 0
Finally
Try
intVersion = intVersion + 1
strVersion = CStr(intVersion)
Dim oAcadSumBuilder As New Autodesk.AutoCAD.DatabaseServices.DatabaseSummaryInfoBuilder
oAcadSumBuilder.Author = oOldAcadSummaryInfo.Author
oAcadSumBuilder.Comments = oOldAcadSummaryInfo.Comments
oAcadSumBuilder.HyperlinkBase = oOldAcadSummaryInfo.HyperlinkBase
oAcadSumBuilder.LastSavedBy = oOldAcadSummaryInfo.LastSavedBy
oAcadSumBuilder.Keywords = oOldAcadSummaryInfo.Author
oAcadSumBuilder.Subject = oOldAcadSummaryInfo.Subject
oAcadSumBuilder.Title = oOldAcadSummaryInfo.Title
oAcadSumBuilder.RevisionNumber = strVersion
oNewAcadSummaryInfo = oAcadSumBuilder.ToDatabaseSummaryInfo()
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbNewLine + "Version Property Incremented to : " & strVersion + vbNewLine)
Catch
End Try
oOldAcadSummaryInfo = Nothing
oNewAcadSummaryInfo = Nothing
oAcadDB = Nothing
intVersion = Nothing
strVersion = Nothing
End Try
End Sub
6 REPLIES 6
You never assign the new summary info to the database.
Instead of
you should write:
oAcadDB.SummaryInfo =
Albert
wrote in message news:4869136@discussion.autodesk.com...
Try
intVersion = 0
Finally
Try
Catch
End Try
oAcadDB = Nothing
End Try
End Sub
Thanks Albert,
I made the following changes
oAcadDB.SummaryInfo = oAcadSumBuilder.ToDatabaseSummaryInfo()
An exception is thrown when attempting to execute this line.
What is the exception?
Albert
wrote in message news:4869203@discussion.autodesk.com...
Thanks Albert,
The exception is as follows
"Object reference not set to an instance of an object."
Stack :
StackTrace " at Autodesk.AutoCAD.DatabaseServices.DatabaseSummaryInfo.CopyToUnmanagedObject(IntPtr unmanagedPointer)
at Autodesk.AutoCAD.DatabaseServices.Database.set_SummaryInfo(DatabaseSummaryInfo value)
at BallAcadPlot.PlotFormats.InitializationCommands.IncrementVersionCounter(Object o, DatabaseIOEventArgs e) in C:\CSLUDTKE\Visual Basic\AcadPlot\AutoCADPlot\PlotFormats.vb:line 196" String
You are running into a bug. Fortunately, there's an easy workaround:
Add the following line before oAcadDB.SummaryInfo =
'dummy call to the CustomProperties property to avoid bug in property setter
of Database.SummaryInfo
Dim dummy As Integer = oAcadSumBuilder.CustomProperties.Count
Albert
wrote in message news:4870227@discussion.autodesk.com...
Stack :
StackTrace " at
unmanagedPointer)
at
value)
at
Thanks Albert !!!
”Boost
